0 Members and 1888 Guests are viewing this topic.
Shokac
Pirate88179
It may have been posted recently but, does any one know the status of the Kapanadze device?  Is he looking for investors?  Is anyone manufacturing his device yet?  What is the hold up?
I have not been able to be on here as much as I should lately.
Thanks for any responses.
Trastos
Quote from: Pirate88179 on August 28, 2010, 07:14:42 AM
Hello,
I started to participate with proof of the replica of Kapagen, after building my replica and do some tests and compare them with other designs Kapandze replicas, and other notes from Tesla, I have personally come to the conclusion that the term is Naudin wrong.
I think people who participated in it, is now collecting more information to design another concept, closer to the design that works, for example, Tiger 2007 design, Don Smith device, and others.
stivep
Quote from: cosmoLV on August 27, 2010, 09:10:34 PM
Kapanadze in 100kv and all Gidraulics systems not used Ground after 15 - 20kv Ground is not needed.
The principle are not in ground but to 10kv grounding are needed.
yes, Boost amplifier are used... but in wery smart way.
P.S. (Tesla worked on wery high currents and in most systems he used ground)
anyway, Tesla not opening free energy device in any patent, he left out that little secret for thoses who are ready and understand this and Tariel get this secret in hard 27 years of work - Respect...
(the principle of this device opens the Leedskalnin`s seecret too - and i`m not joking...)
There are of my early work, this is SR Device - this is not full schematics, there are some principles and lot of parts are not listed, but somebody can try to think :)
***Photo re-sized by Moderator***
Please post no larger than 800 x 600.  Thanks.
Here is what I think:
QuoteGround after 15 - 20kv Ground is not needed.
In the air there is certain level of braking air factor.
In the high voltage for lightning  there is no need for ground and if there is insulator it is compared to the insulating material leakage.
After the leakage provides level of capacitance high enough  the voltage will jump. But before that there is degradation of an insulator( in the air that is ionization)
Ionization is the stage of conductivity !! in V/square centimeter
Ionization does not have to be temporary stage of medium(air) but as long as the voltage(potential)     is not over the limit it becomes steady  stage of the medium.
In reality build up of voltage has to not only stop but decrease in order to maintain the stage.
The same mechanism  must be reviewed in regards to  energizing ferrite particles.
That is why Kapanadze used  first activation and than connected the load.
So  the ground is not needed not because it is the HV but because the stage of the medium is already in "activated" stage by means of "temporary over limit voltage"
In simple example we may compare it to the pipe with water and the rotary blade of the pump.If the preasure is present than pump can overcome  static friction, so than less energy is needed to sustain the motion whan it starts.
In reality it all comes to the same energy usage.
But if you have to jump from point A to B (6feet) where in between there is the hole, you can not crawl.
conclusion  from that is
NO GROUND IS NEEDED !~ not  after 10KV but at any voltage causing  the medium with or without humidity,and at certain initial electric potential- to change
Increase of 1V at the medium may create overflow like in bucket of water.
Ground is measured by its conductivity and area of contact and distance between the points
After lightning strike there is  the path of more conductive area allowing another  lightning to use it.
"fluorescent light bulb"is example of it (- not always)
By bringing medium to conductive stage( at certain frequency,and potential)  -Process of elimination ground is completed.
Wesley
appendix:
MFJ Artificial Ground is the Radio related device simulating ground . 27.5 years ago - this subject was brought to attention of technet.
That is the real prove that the ground can be simulated and/or compromised period !!!
(that should be sufficient for you shokac.-can you respond to that and criticize it? Show me your  level :) )
