0 Members and 197 Guests are viewing this topic.
cosmoLV
Quote from: Pirate88179 on August 28, 2010, 07:14:42 AM
It may have been posted recently but, does any one know the status of the Kapanadze device?  Is he looking for investors?  Is anyone manufacturing his device yet?  What is the hold up?
I have not been able to be on here as much as I should lately.
Thanks for any responses.
i talking with Tariel and he hawe some problems with health :(
but process is started - but i not hawe permission to go in deep details
Keep your chakras opened :)
stivep
Quote from: cosmoLV on August 28, 2010, 12:36:11 PM
Thank you for letting us know about it.
The history repeats again.
It is sad. I wish him well, very well.
Questions: How many of us it takes... How many?
We all shall support each other the best way we can against "real cowards"
Wesley
the_big_m_in_ok
Quote from: cosmoLV on August 27, 2010, 09:10:34 PM
Kapanadze in 100kv and all Gidraulics systems not used Ground after 15 - 20kv Ground is not needed.
The principle are not in ground but to 10kv grounding are needed.
@cosmoLV
Is the atmosphere/earth dynamic used higher than 10-15 kV?  Maybe atmospheric capacitor-to-earth?
yes, Boost amplifier are used... but in wery smart way.
Is that part of the resonance?  Maybe as a carrier frequency?
--Lee
Pirate88179
Thank you very much.  I wish him the best with his health situation.
stivep
Quote from: the_big_m_in_ok on August 28, 2010, 06:24:48 PM
@cosmoLV
Is the atmosphere/earth dynamic used higher than 10-15 kV?  Maybe atmospheric capacitor-to-earth?Is that part of the resonance?  Maybe as a carrier frequency?
--Lee
While changing the frequency of the oscillator from 0 to 500MHz
square wave
Tektronix AWG2041A Arbitrary Waveform Generator was utilized
I have seen on the output of the coil changing voltage but I did not try in this experiment to use kicking coil.
The  first purpose of my scientific investigation was to find variations of resonant points and amplified ferrite response.
At first:
I did not delivered clear independent square wave
I have utilized generating circuit made on TIP142 exactly the same one from known to you schematic  (driving  dual primary coil of the fly back.)
The square wave from Tektronix was delivered in form of mixing signal adding to the pattern.
No significant change was found.
I have noticed "bumps" while approaching  resonance points. but the signal was not at the surprising level.
Previous tests of mine presented on
http://www.youtube.com/watch?v=Cdk-9X_2xOE
and
http://www.youtube.com/watch?v=Imnk4wSwvZk
with the use of
Advantest Network Analyzer R3754B
HP Impedance- Gain/Phase Analyzer HP 4194A
Have been conformed in form of testing under the HV. But The level of response was not as significant as resonance points observed on the screen of the above listed laboratory equipment.
The second purpose of that investigation was mainly  to conform Vladimir Utkin theory that resonance of ferrite is to be felt at frequency up to 300MHz. And He was  right.
I have utilized  pancake coil of secondary of the ferrite coil.by means of the most uneven winding to increase voltage difference between the winds resulting variation of the electromagnetic BEMF response.
Results of that testing have been recorded as the reference for future investigation
The next step will be to try it with the - dual opposite winded secondary winding.
Summary:
1. the effect of non significant voltage/current change in overall mentioned spectrum might be due to the fact of distorted square wave after mixing process.
2. the "bumps" conformed nonlinearity of ferrite structure and no sharp resonance point with response to bandwidth of resonating area of "bumps"
3.Square wave was in non clear form and after it passes  to secondary of fly back it  already change to  form of sign waves, caring on distortion pattern.
One of the significant elements of that additional distortion is the "ringing pattern"
4.In traditional square wave  you have"markers" pointing corners of the square.The corners are points of reference to the frequency of spark gap with respect to the gap distance.
the more clear the square is delivered the "more vital" is response of the ferrite.
5. That "vitality" is the factor equal to the ionization of the air ( look into my previous post)
At that point  the ferrite is in the stage of the air after  lightning strike happened.
But the ferrite particles are not energized as of yet. for the purpose of energizing the kicking coil must put into the motion.
The self capacitance is the tuning factor and you right. Frequency of dual resonance response is to be applied while capacitance is one of tuning factors.
Concentrating on single resonance point might be not the smartest choice in this particular area.
Thank you for your attention
Wesley
Ps: That should be enough for you Shokac show me the rest of it :) :)
I did not see your comment of the previous post of mine directed to you?
What are you waiting for :) :) ?
