0 Members and 124 Guests are viewing this topic.
the_big_m_in_ok
Quote from: Shokac on August 29, 2010, 10:27:46 AM
Does anyone know if there is spark gap can reproduce all frequencies or only to a certain limit?
There appears to be an upper limit of a few mega Hertz.  The lower limit should be in the audio human hearing range:
http://www.ewh.ieee.org/reg/7/millennium/radio/radio_radioscientist.html
--Lee
jeanna
Quote from: Shokac on August 29, 2010, 07:27:46 AM
I believe the larger the spark, the more it includes in waves.
It takes longer to build up a higher voltage to produce the bigger spark, so in general,  the higher the frequency, the lower the voltage can be.
So if the spark gap will allow some variance, you can get a wide range based on the input, remembering that you need time to build more voltage.
I guess a related calculation is that if you have a fixed gap and so a fixed voltage, you will get fewer sparks with less input, but if there is enough input you can get more sparks, meaning higher frequency.
If you make an accumulation type circuit for your input, like what is in the camera flash, you need to wait longer for the 300v needed to make the flash, and the voltage is always the same output.
(I wish I knew how to build one of those accumulators!
I know it has to do with a cap and diodes, but I have problems with diodes...  :'( )
jeanna
LtBolo
Quote from: the_big_m_in_ok on August 30, 2010, 05:04:43 PM
--Lee
In our experiments with the Tesla Hairpin, we've seen resonances of up to ~35Mhz, but I have no reason to believe it wouldn't go higher. That was with a spark of about 1". The discharge at that level is insanely loud...probably in excess of 120db of white noise...ouch. We bought shooting hearing protectors to wear when working in the lab. So yeah...it extends well into the audio range as well.
