0 Members and 371 Guests are viewing this topic.
DimaWari
@Stivep
Thanks Bro, Eve though i dont know what you said  ;D. Do you think inrush current is what consumed when flash occur?. And if it did, do you think its the same with "the kick" that SM wants to point out?. SR said if i'm not mistaken the role of his spark gap was to remove the voltage from the line?. Are they related? And even Tito said "you have to put the pressure to the capacitor"?
Do you have any idea how to use in-rush current to obtain extra energy?
forest
Quote from: DimaWari on September 01, 2010, 04:14:58 AM
@Stivep
Yes,we have to find circuit potential. Those two tips are tightly connected.
stivep
Quote from: forest on September 01, 2010, 02:26:34 PM
Would that be a shame if I say I do not know yet? or I'm not sure yet ?
Another words when I stated something on this forum I was 100% convinced that I'm right.
At this time I'm not convinced  100%
I do not want  to put anyone in wrong thinking because of respect  I have earn with you guys
I'm NOT showman.
Wesley
PS: this  kind of statement says only that what looks simple is not simple at all.
stivep
Philosophical and physical calculation:
some basic about spark:
when you have 10kg hammer  on the table it puts the pressure( vectorized force) of 10kg on the table but when hammer slipped down from the shelf  from 3 feet hight then impact will be much greater than leading force.
The direction of the force is the same but the impact is oveunity. (So what if it cost energy of gravity, who cares?. Does cost you a dime?)
Even if we subtract energy of sliding the hammer from the shelf the total impact  energy is greater
another example:
We have  two 10kg magnets (toroidal with hole inside) and one of them is on the table but second one is repealing  due to magnetic force.
In the middle we have vertical plastic  rod .
The upper magnet appearers to be suspended in the air
Someone pushes that magnet  from the top of it  down ( vector down)  with one pulse only.
The magnet recovers its own energy by vector force oriented up.
1.Can anyone explain what this energy is coming from?
2. does magnets represent potential or kinetic energy?
3.Do we have overunity that is  so damn easy to prove? !!!!!!!!!!!!!!!!
4. even if after 100 years the distance between the magnets  is smaller who cares.
5 everything that  works longer  with no additional cost than typical life span of human is(at minimum) perpetual motion  yes? or no? - (in philosophical mathematics)
6.Do you see similarity between spark  and energy of spark and hammer?
7. Do you see similarity of recovering energy of spark converted into the "ferrite activation" force
or
simple example: that if one knock you in the head instead of the same force being applied -"of  gentle female hand spread on your body."
Than
Your attention to the knock will be immediate reaction  activating your brain instead of slow activation of another part of your body that will not be as creative?
Wesley
Ps: Think about the force of jumping spark and diameter of the spark, and
compare it to pulse(knock) of 10kg applied to the thick nail and 10kg (knock)applied to  needle (with respect to the fact  that needle is not going to brake)
dole
I am very sorry to interrupt your discussion,  this is last research, HF HV AC dipole generate potential difference, if  you connect one pole to ground this will generate strong vibration on the other pole. I still do not know how to utilities this.  It may depend on inductive relation, one wired Tesla electricity transfer, still testing.  Tesla transformer -> HV output 10Kv AC â€"> one wired to ground -> other to copper coil 30 turns-> strong vibration. Ps. Kapandze never use ground connection directly to load, carefully watching will conclude in induction relation, same as Tesla.
d.
