0 Members and 275 Guests are viewing this topic.
hartiberlin
Hmm, let´s just calculate some numbers:
Maybe it is also running like this,
that the burried cooler grill versus the water line
has a small voltage difference, like 0.5 to 1 Volts,
but could support a higher amperage this way ?
So if it would work like a pure galvanic earth battery,
it would probably put out only maximum 0.7 to 1 Volts
from the metall difference between copper waterpipe
and iron cooler grill.
Okay, let us assume it could at least put out 2 amps,
which would be already pretty much for an earth battery,
then it would only give a maximum power output
of 2 Watts or something like this,
but not the shown 5 x 100 ? Watts bulbs shown...
So the question is, does it use the Tesla coil  to excite
radioactive sand in the ground to stimulate faster
beta decay and thus deliver free electrons
simular to the Morray  and the Methernitha devices ?
At this high power level I believe it must be something
like this cause no simple galvanic earth battery
can deliver such levels of power.
Would be good, if somebody could translate the
video and put subtitles ontop of it and
repost the videos.
Many thanks in advance.
Regards, Stefan.
nievesoliveras
@hartiberlin
What I mean with the circuit on post #28 to be a key is because on the video from the same guy that posted the other 7 videos.
This configuration is run with a AA battery.
It is known that at least 2 volts can be gotten from an earth battery.
So I thought that this circuit is used or can be used to produce the 7 volts that the video is showing and somehow doubling or quatrupling several times with the circuit inside the green box, they are getting the 12 or 24 volts needed to run the 220volts inverter.
And that inverter is able to turn on the light bulbs without the starting battery with the electricity produced starting with the earth battery 2volts.
This is just an idea I thought.
Jesus
hartiberlin
Quote from: Nikola Tesla on July 01, 2009, 10:57:07 AM
You said the same thing about T. Henry Moray and his radioactive stone.
In the case of Morray, it is verified, that it was using the
excited radioactive decay from this radioactive doped
diodes(valves) he used.
I have already collected many stones from Rivers, etc.
to begin some experiments in the coming winter to
see, which stones or extracted sand from it can
be pulsed with High voltage to extract useful
electrical power.
Inside the Methernitha Testatika backside
leyden jars were also mountain crystals which were pulsed
via High Voltage pulses and this excites their Beta decay.
Where do you think these high power levels are coming from
otherwise ?
Glavanic power outputs would be just too small for it.
Regards, Stefan.
Nikola Tesla
Quote from: hartiberlin on July 01, 2009, 11:10:44 AM
otherwise ?
They are comming from the sun.
Nikola.
Cap-Z-ro
I noticed they took the time to properly align the radiator in the ground before covering it with dirt...that seems to suggest an earth battery component in combination with the copper water pipe.
That would tie in with what jesus said.
Hope that helps out some.
Regards...
