0 Members and 282 Guests are viewing this topic.
vdomov
In Russian Forum next-energy.2x2forum.ru User:Mike Post:
Parameters of Kapanadze Device:
1)Based on Tesla Transformer (ТТ) with working frequency of 200-300 kHz (Only in this range !!!)
2)length of Secondary - one forth of wave length.
3)Resonance of ТТ tuning with change Capacitor's capacitance.
4)Output Coil - 1/4 of wave length (maybe)
5)No Ferromagnetic Core!
6)On 100kW Device Sparks only for Visual indication of energy transmitting on output coil. if used bridges instead spark gap, the device will still work!!!
7)Tariel says: make ТТ in resonance and you will see immediately all is in front you eyes.
SR has not have working device.
9)Without Calculations noting will happen, Tariel accidentally discover this effect working on other device.
10)Power output of Device is unlimited.
11)Tariel has contract agreements to not disclosure all detail of his work.
12)Working Device Exist.
One More used ordinary coil, with biffilar you will get more efficiency, but with ordinary coil the device will still work.
This Info has been obtained 10.09.2010 personally of Mike in time of his half hour videoconference with Т.Капанадзе on Skype, just before conference on ес.
stivep
Quote from: vdomov on September 13, 2010, 09:42:25 AM
7)Tariel says: make ТТ in в resonance and you will see immediately all is in front you eyes.
Here is the question:
1.for the  frequency of 375 Khz there is requirement of 640m of wire if we take 1/4 of  lambda than we come to conclusion that length of singular coil to consist resonant factor will be 123m roughly 369 feet
times  (2) for secondary coil ( in series) = 738 feet of wire
within the given range 200 to 300 KHz the amount of wire will be  additional  </> 150 feet(per coil that means x2=300feet of wire)
Do you see presence of such amount of wire?
2.The total power of transformer at its maximum is 3 KV  at 40 W
What is the total power drown from the  outlet.?
What is the power o light bulb (rated at 220) with regards to being powered at X? V( at contacts of light bulb)
and
With respect to the fact that Tungus( wolfram) reacts differently to HF than to 60Hz.
Typical example will be
regular light bulb held in your hand and Katcher
with no  significant harm to your body you can hold this light bulb with your own  fingers touching outer contact.(no plate needed) proper insulation (from the ground)required
or
http://www.youtube.com/watch?v=lfFlfeg6AfM
If the amount of current drown by Light bulb will be applied to  your body  directly from the outlet and you will be connected in parallel to light bulb than  the effect will be disaster.
would than the total calculation  all of the light bulbs (in series) give you overunity?
Wesley
PS:Anyone want to respond?
additional question:is it
QuoteOn 100kW
when transformer shows 40W?
forest
What does it mean ? What is the "B resonance" ?
Dankie1
I wish to listen to this videoconference for myself , who is mike , did he record the conference . Why would Tariel accord him a video conference and not others .
I see no such lenght of wire .
So you say SR hasd not a working device , perhaps he tries to make him appear as guru and feed off others who are close ? His layout is extremely mangled .
show me link of what Mike said .
dllabarre
Quote from: Dankie1 on September 13, 2010, 12:27:45 PM
Same old Dankie from the Stanley Meyers forums.........
The URL was posted below to the forum where Mike posted and from there you'll find the link to the document to download of the conversation.
I tried to read it but Tariel's words are never translated by google.
Everyone else words are translated except Tariel.  This is not the first time I've come to this problem.  Does he speak in some forgotten language or does he mis-spell all his words so google cannot translate?
I do not know.
If you speak Russian you may be able to read what Tariel says.
21:49:43 tarielkapanadze: zdrastvuite
21:52:09 tarielkapanadze: prostite u nas segodnia bilo 8 vstrech i nikak ne doshli ruki
21:53:00 tarielkapanadze: mi segodnia uletaem i prosim prostit nas no ni kak ne uspevaem otveti
21:53:18 Ð' чаÑ, вÑ...одиÑ, Green Sheet.
21:53:39 tarielkapanadze: kak doletim i ustroemsia podkliuchim net obezatelno prodoljim
21:53:40 Ð' чаÑ, вÑ...одиÑ, vlad1112.
22:01:06 tarielkapanadze: ia dumaiu maxsimum cherez nedeliu a mojet i ranshe
22:06:33 tarielkapanadze: prostite nas do novix vstresh obezatelno sviajemsia
22:06:58 tarielkapanadze: ezdit budev vo vse strani pochti
22:07:12 tarielkapanadze: mojet i nameste uvidemsia
22:07:20 tarielkapanadze: dosvidania
DonL
