0 Members and 37 Guests are viewing this topic.
Dankie1
Quote from: DimaWari on September 15, 2010, 03:09:43 AM
@Dankie1
Doesn't mean much? Would it really be this phenomena is the real evidence of how earth magnetic field affects the first electron flow in a circuit?
How about Bart, Sparks, Wesley? Do you agree with Dankie1?
Hmm , you have caught me flatfooted ,  I never asked myself exactly why that was the case for the first electron flow . I think its because the little magnet domains are not fully aligned before the current flow .
It is no anomaly , but perhaps understanding causality is important .
DimaWari
@dankie1
Think about this post....
Tao's Post:
"Lets talk about the 'kick.'
When the old Edison DC generators were turned on, back in the day, they released this 'kick' and killed many workers in the process.
A man by the name of Tesla had seen this.
He wondered how and why this 'kick' would occur.
So he experimented with wire and disruptive discharges from capacitors.
It was found by him that this kick could be made so powerful that it could explode wires instantly.
This kick came out of the wires perpendicularly.
He discharged capacitors into stout wire and through a spark gap.
The key to the kick's strength and appearance was in how fast Tesla discharged the capacitors into the spark gap AND how fast Tesla STOPPED the flow of current AT the spark gap.
Tesla used all types of devices to stop this flow of current, magnets, a flame, counter-rotating engines.
His goals were to get the time in which the discharge is STOPPED to be much quicker.
As Tesla did this he found that the perpendicular radiations, the ones from the wires, caused electrical effects to appear in wires and other copper/metal materials near the STOPPED current/discharge.
These electrical effects could be made to create electrons on other wires and copper around his STOPPED current/discharge wire.
SM's comment about Tao's fantastic post:
"So Lindsay, this guy definitely has the secret. I do not know if he will be able to duplicate power
generation, but he does have the secret.
Do you think he knows it?
The only part he doesn't have any idea about is that by starting the oscillation you cause the
current to flow in the collector (our dc pulsed bias) which causes the magnification of the process within the collector
which will ultimately produce the greater voltage and power in usable amounts during operation."
Dankie1
I really do not understand what you mean by ''kick'' , or 'in-rush-current' . It seems like you are talking in pseudoscience terms and I understood the classical term .
The coined term 'inrush-current' is often used in everyday electronics , usually it is the high power at startup in either transformer coupled amplifiers or large filter capacitor banks in DC power supplies .
Perhaps if you showed me a schematic what you mean by 'kick' or 'in-rush-current' .
DimaWari
Ooopps!!!! sorry i  dont mean to be rude.. maybe i just misunderstood it.. The idea of inrush current and kicks are the same (somehow).. My apology
stivep
Quote from: stivep on September 14, 2010, 09:43:41 AM
http://webcache.googleusercontent.com/search?q=cache:xDQw9lpbOxoJ:www.airdux.com/coil-design.html+illumitronic+engineering&cd=12&hl=en&ct=clnk&gl=us
for whoever wants to know what is the resonance frequency of coil you have winded.
Note:
This applies to air coils although the ferrite addition is amplification factor  not frequency change factor.
I will confirm that note with TechNet.
Wesley
http://en.wikipedia.org/wiki/Rlc_circuit
QuoteVariable tuned circuits
A very frequent use of these circuits is in the tuning circuits of analogue radios. Adjustable tuning is commonly achieved with a parallel plate variable capacitor which allows the value of C to be changed and tune to stations on different frequencies. For the IF stage in the radio where the tuning is preset in the factory the more usual solution is an adjustable core in the inductor to adjust L. In this design the core (made of a high permeability material that has the effect of increasing inductance) is threaded so that it can be screwed further in, or screwed further out of the inductor winding as required.
This seemed to be not at the curse of actual conversation although it is essential to Kapanadze.
Wesley
PS: in Practice I have seen slight  change of resonant frequency of the coil with addition to ferrite rod
