dole
Quote from: baroutologos on September 17, 2010, 02:15:33 AM
Hey Dole. I want to ask something. You talk about oscillation and from what i can see in the video this is slowing donw to a stop right? Do you suggest this happens with a single cap discarge or the HV DC source is working normally?
Hi,
It will be my pleasure, but pleas again this is how I see and could be a completely wrong in your eyes. We can do simple experiment, connect transformer 220/12 in reverse with the sound power amplifier, and connect transformer 12V side to the output for the loudspeaker and 220V to the lamp (50W or 25W). To the sound amplifier connect PC with simple software sound frequency generator and start with the low frequency carefully increasing. At the certain point you will see lamp is glowing and if you go further the glow will diminish or completely disappear. This is simplified because of impedance match according to frequency imposed (and some other ting, but not to complicate for now). At that certain point we also have resonance of two magnetically coupled systems. You must also note that energy of the both systems is impressed.
We may now agree that earth (air, everything) have some magnetic properties (capacity) and what was not artificial generated, so we may do some coupling to that, but as we see from previous example we must fulfill requirements of resonance for particular purpose what is in our case extracting energy (capacity) from the nature. And to not complicate this with the damping factor, what is a relation between RLC and for small/big values of LC respectively to R we will have undamped or damped oscillation.
Now our system has to set in motion both sides in the resonance from one source and couple them magnetically (induction). The “right” ground system have own natural freqency and huge static energy. The “left” one artificial system has to be designed to withstand amount of energy set in motion. So practically in the small system we may charge the condenser on the “left” side and discharge them to the “right” (grounded) in rate of its natural frequency. “Right” will naturally start to respond and convert some of the static energy to dynamic in response and return back to “left”.(BEMF). Since the “left” already swings in the same frequency, return will be added to the “left” and process repeats itself. Properly tuned we will fast destroy the system if we not convert gain but then we introduce new parameter and the system has to be tuned again.
Energy must be taken from the “left” (inductively I believe) in proper interval and not from the ”right” as shown in Bearden schematic proposal , but this I do not know yet.
(English is not my language either)
Answer: unturned oscillation will slow down and stop; source is used just to start oscillation ideally.
Energy conversion  system close to natural oscillation will use some amount of energy but less then produced,
depends how close. Energy is used only to charge the condensers, under discharge A meter is showing 0, but with not tuned R we have almost no oscillation, high damping factor.
Pardon me if you find this not relevant I may simple delete it.
d.
dllabarre
Quote from: dole on September 17, 2010, 10:04:22 AM
Hi,
d.
It's very relevant!!!!
And you can delete it if you want to but I already have a copy  ;D
Is a Neon Sign Transformer with output of 2kV DC and 5mA enough to even give this a shot or a waste of time?  I hate wasting time  :'(
I have a 110V input 10kV output transformer on order also.
Probably should just wait for it to come?
DonL
Pirate88179
Don:
If you don't mind my asking, where did you order the 10kv transformer from and how much roughly?
Thanks,
dllabarre
Quote from: Pirate88179 on September 17, 2010, 04:58:26 PM
Don:
Thanks,
I bid on a used one on Ebay a few days ago for $15 + $15 shipping in US but was outbid.  Didn't matter because there were 2-3 others for sale.
Today I found one at a local Heating Supply store for $36 brand new.
I plan to pick it up tomorrow.
Check Ebay:
http://shop.ebay.com/?_from=R40&_trksid=p3907.m570.l1313&_nkw=ignition+transformer&_sacat=See-All-Categories
Hope this helps.  :)
DonL
Pirate88179
