0 Members and 293 Guests are viewing this topic.
LtBolo
I mentioned this before, and nobody commented...but...the FreeEnergyItalia guy on Youtube with purported OU, I haven't seen any discussion of his devices. Does anybody here have any info on it? It appears to be a Tesla coil and some capacitive plates around it. At some level it seems to have functional similarities to some of Kapanadze's devices.
Comments?
http://www.youtube.com/user/FreeEnergyItalia#p/u/12/13KPCNup_YE
exnihiloest
Quote from: baroutologos on September 23, 2010, 02:06:10 AM
What about of almost two years experimenting based on many internet's favourite OU principles as (Bedini, Adams, Meg, Perepiteia, Rotoverter, Tesla Coils, Kapanadze setups, Melichenko, pure LC resonance setups, allaged Kapanadze ferrite core/inverter setups, etc)
YES. I have experimeneted with all these and much more, yet a single principle of OU operation i could not found.
And the big fact of course, (apart from mine potential incopetence in this field) that no-one trustworthy has ever replicate or there is not a single third party replication of any of the hundreds OU machines.
I am exactly at the same point.
Without a single third party replication we can say there is not one OU machine, because what can't be observed is not fact and not science.
WilbyInebriated
where is the record of your experiments? where are the pictures, video, recording of raw data, measurments, etc. ad infintum, ad nauseam? if you don't have these, then essentially your experiments never happened... they are just anecdotal stories.
trustworthy is subjective... and irrelevant. if a device works, it works. regardless of whether or not someone 'trustworthy' has replicated it.
Enough for you to put in scepticism?
enough to put your competence in scepticism anyways...
Quote from: exnihiloest on September 23, 2010, 10:04:49 AM
you can't observe the wind... so it is not fact?
dllabarre
Quote from: LtBolo on September 23, 2010, 09:33:22 AM
Comments?
Some translations from his videos:
Newest 4 videos:
1) Machine Overunity Transformer with a combination of Grid Tie Inverter 300-Wat.Dalla maccnina emerge from the network in stable condition, on average 6 Amp at a voltage average of about 20 volts which is approximately 120 Wat. The test is read at 1 Amp tester what had just accesa.La machine is connected to the network using only mechanical timer to stop running notturna.In this stage it is premature to quantify the savings effettivo.Il transformer in this configuration works in a sixth dela his power and is therefore not entirely under effort
2) Overunity machine made with three transformers in ballast from 1.5 to 2 blue and one for the Amp caduno carichi.I blue ballast transformers were accopppiati capacitor phase shift of 20 uF.Il load has been rocked by turning the dimmer demonstrate that the potentiality is lost in overcoming the benefit dell'Overunity. Pm 300 (digital meter on the wall) shows exceptional values, but obviously the potential created daii transformers blue is used by the third processor to supply a maximum load of about 800 Wat, passing also the tolerance of that which is 600 Wat.La voltage is limited but the current is strong for this machine but the principle is really straordinario.Il panel shows 16-beam lamps by vehicle DC power with 40 each, of Wat. but the test is gone over thoroughly
3) Overunity Transformer 600 VA of power from dimmer potenza.Trasformatore x mixed resistive - inductive 500 VA., Powered by AC current from 220 V rectified by diode bridges 4, The outputs were connected to a series of halogen lamps for a load approximately 200 VA.Sulla power strip transformer are also connected two other transformers which consists of a series of 6 and the other by a single capacitor with no load. In the series of 6 has been connected to a load of about 100 by No Go Automobile.In last two lamps are connected on the same ciabbatta 4 lamps lit in the 10 VA caduna regularly test.Il overall load on the circuit shown is approximately about 300 VA with defendants oscillating from 0 to 4 VA
4) Performed in parallel machine Overunity No 6 250 W AC transformers connected to the 220 Ac and rectified by n. 8 diode bridges connected in parallel and a capacitor DC 22000 uF -50 V. Imput network wat is 8, the output is approximately 150 W of power on the part of which x halogen lamps, and part to the batteries via the DC controller Steca voltage
Older video from the link posted in the Quote:
We present a Overunity Transformer machine made by optimizing the
components of the circuitry described in the preceding videos (older than this video) and made up by (in short): two condenser towers in perforated aluminum, one internal coil and an external one wired to the circuit, 12 Red Bottles Capacitor, linked by a perforated grid to a switch group, 1 Spark Gap and 1 NST.
DonL
wings
Quote from: dllabarre on September 23, 2010, 11:28:34 AM
Newest 4 videos:
DonL
some diagram of previuos version?
http://www.youtube.com/user/FreeEnergyItalia#p/u/14/0zOkszkM1SY
