0 Members and 134 Guests are viewing this topic.
dllabarre
I read where tiger2007 got his device working but couldn't control/regulate all the power produced.
Cosmo,
Is this schematic from Tiger2007 similar to Mr. Kapanadze device except Mr. Kapanadze does not use ferrite?
Thank you
DonL
cosmoLV
Quote from: dllabarre on September 26, 2010, 11:13:04 AM
Cosmo,
Thank you
DonL
No, no no...
tiger try this setup around three months without results - think why he not get FE from it? :)
You need start from the scratch (yourself)
The key in SR device is to magnetize and demagnetize ferrite without loses.
High voltage and high frequency make ferrite demagnetise - it makes from ferrite Black Matter who sucks all electromagnet power from wires. and in this way this is effective way to demagnetize.
by the way, all scientists in the world try to make Black Matter without results, but there it is.
SR this process call "Dead Magnetic Field"
Keep your chakras opened :)
dllabarre
Quote from: cosmoLV on September 26, 2010, 12:20:21 PM
No, no no...
Thank you.
I didn't want someone new to waste their time going down this path if it doesn't work.
DonL
LtBolo
Quote from: minde4000 on September 26, 2010, 01:10:59 AM
And why noone pays attention where (@Kapanadze demo video) Frolov is pointing finger at and the exect words he says? If just someone could reingeneer that device from "gas" into "electric" ... in few pdfs that device HAS BEEN connected as analog to tesla transformer..
Is he referring to a refrigeration system when he makes the comment?
Refrigeration systems are well known to have a COP > 1...over 10 in best cases. Of course the resulting energy is heat, which isn't the easiest to work with. However, the key question is how does a refrigeration system use a small amount of energy to extract or transfer a large amount of energy? Regardless of where it comes from, when I can use 1 unit of energy to extract 10 units of energy, that is a good thing.
Whether is it heat or electricity, it would seem that we are harnessing quantum level energies. In the refrigeration example, that involves phase change. There have been similar discussions of ionization of gases...H2 -> 2H -> H2...doing the same kind of things. Perhaps electricity has similar possibilities.
Don't have any sense of its credibility, but the Aether Physics Model (APM) claims that there are 2 distinctly different types of charge...electrostatic and electromagnetic. That also agrees pretty well with Dollard, who called it magnetodielectric and electromagnetic, so there may be merit to the theory. If there are quantum energy pumping effects in the transition between the two forms of charge, much like liquid to gas to liquid, then the answer may lie in going from electromagnetic to electrostatic/magnetodielectric to electromagnetic.
It would be a stretch to say that either charge type is liquid or gas...but...the electrostatic output of a Tesla coil is certainly more like a gas than the input. Again, this is all a very big stretch, but we see that the same patterns play out over and over in nature. It wouldn't bother me in the slightest to find that electric charge follows similar patterns.
I guess the question is what you do about it? If a Tesla coil allows you to convert electromagnetic energy into electrostatic energy, then what type of device does the reverse? A normal step-down transformer? I'm guessing not...since the Telsa coil isn't a normal step-up transformer.
Since a Tesla coil is just a transmission line with series capacitance and parallel inductance, then would a transmission line that is series inductance and parallel capacitance do the opposite? Tuned section of coax? Or bifilar windings...which behave more like caps...tuned with series inductance?
Just brainstorming...
Dankie1
Quote from: cosmoLV on September 26, 2010, 11:07:26 AM
DC have lot of loses - Tesla worked mostly with AC
You are confused ...DC have alot of losses ? No AC have alot of losses .
Tesla didnt have access to tubes for his HF experiments ,  he used LC resonance or mechanical switches , for that you need HVDC to charge the capacitor for the release .
