0 Members and 42 Guests are viewing this topic.
core
Quote from: cosmoLV on September 26, 2010, 08:44:41 PM
Stop make a brawl :)
just make experiment:
Take ferrite rod OR rod from toroid's wrap around Tesla coil with isolated cable connect it through sparkgap, other end to ground
make second coil around it and apply DC or AC current to make electromagnet
Results:
When HV are in first coil and DC or AC on second coil, you will not get an electromagnet, but if you turn off HV then ferrite turns into electromagnet. (now you can try to synchronise it with sparkgap and play with sparkgap polarisation) it need to spark with little needles very steady and quiet
Try it with AC and DC
Tesla worked with AC and with rotary breaker he break signal in half way, but we can work using generator for it, like Emitter Follower. but for start it is great to do it with AC - you can take 9 to 15 volts - good for start.
just try - because we can do theories for all us life and get nothing ;)
and last: device are very simple, so simple than, nobody Kan make it - i think this is because everybody try to find something like Back EMF OR other Sh*t - that all stuff are absolutely stupid and there nothing to do with Free energy (i mean all Bedini devices and technology) forget it, there are no free energy and never had
Yet another great post that goes into my Cosmo file. I did not know that ferrite reacted in such a way.
Respectfully,
Core
cropersh
cosmoLV, thank you for all informations. You give importent details to concept. From your explenetion I understand that device is parametric resonancy. HV cause primary DC/AC coil to charge quickly and with very low energy. Then HV shut off and coil discharging with very high inductance and energy.
Is this concept correct? I will go try experiment on this.
baroutologos
Quote from: core on September 26, 2010, 08:57:33 PM
The diagram.
Thanks core for the reply. Its pretty obvious from your diagram what you observed.
The two (2) transformers topology is able at drawing / giving a fixed amount of energy to the lamp. (dim) By applying the HV ala Tesla type to the second transformer output, it is evident the transformer works as a blocking inductor and the load is pulsed by capacitor's discharges and ringing.
Of course most of the energy that the HV circuit can provide is spent on the lamp, thus having a combined effect.
Verification
Try observe how the lamp behaves when the HV-capacitor-Spark gap works on the lamp whereas the transformers are not working. Note that effect (white flashes inside the lamp and some brilliancy) Then combine it with lamp plainly driven by transformers.
With some experience and observation you can really say whether there is any gain at the setup.
baroutologos
Results:
Hey Cosmo! Your last sentences are wise my friend. I got expelled from energetic forum once for good because i rejected Bedini's machines as hype and non-fuctional. (fictional actially) So, only here i may post. Yea, i agree also, its time to have some experiment able to demonstrate a principle rather talking without end.
Regarding the simple experiment you suggest. Can you draw it?
ElectricGoose
