0 Members and 28 Guests are viewing this topic.
baroutologos
If you can't observe the wind, you have a serious problem...
Don't even bother man... he is not worth it
forest
Quote from: cosmoLV on September 27, 2010, 11:04:14 PM
Tariel have Sugar Diabetic - i think i write it correct in English. in Latin it spells: "diabetes mellitus"
core - i recommend these: http://cgi.ebay.com/Toroid-Ferrite-Cores-M2000NM-44x27x8-USSR-89-QTY-12-/310217966008?pt=LH_DefaultDomain_0&hash=item483a6e81b8
you will need 19 to 24 of them, but 12 for tests are great
i want to remind that you cannot get out from anything more than putting in, maybe you can get more voltage but no more amperes and so on, but there are no way to bypass physics laws - there is something more, what is not write in books, in no one book are writed this as i know.
so this experiment shows all, if you focus on right point of view.
i wish good luck to everybody.
Well,maybe except one book with one small paragraph...
baroutologos
Quote from: cosmoLV on September 27, 2010, 10:07:32 PM
One more thing...
you connot get out more than putting in, this is not the principle of device.
try experiment what i told on previus page:
this is the diagram of experiment setup:
Results:
When HV are in first coil and DC or AC on second coil, you will not get an electromagnet, but if you turn off HV then ferrite turns into electromagnet. (you can place near ferrite a magnet to hear the effect)
Hey Cosmo, i have tried several things like that (not that) with no success. Yes i haved use iron core and ferrite one 2000 pearmetability a bit smaller in dimensions but similar in making (USSR stock) to the one you mention. For HV i have used my Ignition coil pulsed at several KHz.
EIther applying HV via a spark-gap or not applying at all the core behaves as an electromagnet.
ps: In the photo i used AC directly from transformer. I have used also extensively Inverter setup (NPN-PNP pair) with the same result. The HV HF does not affect electromagnet performance at ALL.
What you say?
cropersh
Hello all.
Today I try experement as cosmo say. I make diagrama. I use flyback HV from TV.
I try see difference in lamp when HV is on and off but difference is small. Lamp slightly makes more light when HV is on.
Is this correct direction?
dllabarre
Quote from: exnihiloest on September 28, 2010, 03:14:21 AM
If you can't observe the wind, you have a serious problem. Even prehistoric humans could observe wind.
We can observe the wind by its effects which are facts. We can even measure its speed (see "anemometer"). You should learn what an "observation" is. "To observe" doesn't mean "to see with the eyes". It means to acquire the proof of the reality of a phenomenon by the evidence of its effects and the possibility to measure its physical quantities.
When someone comes on the thread talking negatively, demeaning, insulting, disrupting the positive flow, all creativity stops and the idea just sits there not growing.  Thus the thread dies off.
Just look back several pages to when this thread was dieing and compare it to these past few days with the excitement of new ideas and new ways of thinking.  This thread is alive again.
We don't need negative words or thoughts that will stifle (stop) the positive flow.
Please ignore anyone with negative comments.  Just don't give their negativity any energy by responding to their comment.
JUST SAY NO (ignore) to Negativity!
DonL
