0 Members and 28 Guests are viewing this topic.
cosmoLV
Quote from: baroutologos on September 28, 2010, 05:38:52 AM
Hey Cosmo, i have tried several things like that (not that) with no success. Yes i haved use iron core and ferrite one 2000 pearmetability a bit smaller in dimensions but similar in making (USSR stock) to the one you mention. For HV i have used my Ignition coil pulsed at several KHz.
EIther applying HV via a spark-gap or not applying at all the core behaves as an electromagnet.
ps: In the photo i used AC directly from transformer. I have used also extensively Inverter setup (NPN-PNP pair) with the same result. The HV HF does not affect electromagnet performance at ALL.
What you say?
you use wrong wires, see my image. wires need to bee with isolation, this is great for spacing.
you need usual electric wire - not magnet wire. on first layer of coil are something about 40 turns
Keep your chakras opened :)
LtBolo
Quote from: cosmoLV on September 27, 2010, 11:04:14 PM
i want to remind that you cannot get out from anything more than putting in, maybe you can get more voltage but no more amperes and so on, but there are no way to bypass physics laws - there is something more, what is not write in books, in no one book are writed this as i know.
so this experiment shows all, if you focus on right point of view.
Cosmo, you have been patiently trying to guide people in the right direction for a while now, and many people have treated you badly. I applaud your persistence and willingness to keep trying.
If there are unwritten physical laws that make it possible to do what we are all seeking, then no government or corporation can own that physical law...only a particular implementation of devices that use those laws. Scientific knowledge is generally published in journals and is not generally kept secret. I think you would be doing everyone a favor if you would simply talk about the unwritten physics law, rather than leading us around in the dark hoping that we will stumble into it.
grizli
Quote from: cosmoLV on September 27, 2010, 08:28:15 PM
ok, make one of the devices SR or Tariel and then teach us how to transmitt from TC without loses and get Free energy.
Talking is great thing, but if starting theories, then all real work stops.
P.S.
Tariel work with magnetic fields too but in little bit different way as SR, yes he use tesla coil, but bifilar - but i do not want to get there too deep - specialy on Tariel device.
and "NO" there are not using electric Transmission system with TC - this is all theories and it ends with fail.
Transmitting electricity wirelesly, this is only technology to transmit and it is nothing to do with free energy.
YOU just claim you KNOW how Tariel device work.
I have NO prove yet hehe.. you have to give us something first :D so I cn trust you.
Tarial cleims his device is based on Tesla work after all
cosmoLV
Quote from: grizli on September 28, 2010, 12:58:12 PM
i say already why i`m not showing my works!
That's it, believe or not - your problem.
They who want to make it, they make.
yes i talked with Tariel personaly. I need approve this too, how and why? this is offtopic anyway...
P.S. you are talked like you know how to work this setups! why you talk if you do not know?
LtBolo
Quote from: cosmoLV on September 28, 2010, 01:07:48 PM
Cosmo, you don't owe anyone anything. And truthfully, your work...or even Tariel's work...is not the real issue here. I think the issue is the unwritten physics principle.
It clearly isn't that simple. People have been playing with this stuff for decades and only a very few have stumbled onto the physics principle that you describe.
Tariel owns his devices and his patents...he does not own the physics. If he was willing to share the physics with you, then he is presumably willing to do so with others.
The experiment you suggested...does it demonstrate the physics principle?
The only thing I see about what you described is that the amount of HVHF power needed to scramble the magnetic domains may be lower than the amount of magnetic energy in the low voltage coil. That would be an interesting effect that might have implications for something like the MEG, where permanent magnets are used. I could also see that similar effects might be useful for magnetic shielding. On the other hand, if the HVHF energy is the same as the low voltage energy, I don't see anything interesting about using one coil to neutralize the field of another.
