0 Members and 1854 Guests are viewing this topic.
grizli
Quote from: LtBolo on October 01, 2010, 03:52:32 PM
So then the big Tesla coils are only for show, and do not have anything to do with the actual device? Sneaky.
Stis is becoming more and more WEIRD hehe  ;D
Maybe there is little green zombie inside Tesla coil haha :D
cosmoLV
Quote from: dole on October 02, 2010, 08:57:14 AM
@cosmoLV
I may ask you some questions and  I would appreciate your time if you could elaborate, for simplicity you may just answer yes or no.
If not, hopefully someone else would be able to do some correction or opinion.
Referring to last circuit drawing:
http://www.overunity.com/index.php?action=dlattach;topic=7679.0;attach=47977
1.   Dose the left side of the SG represent the ordinary AC HV source?
2.   Dose the ground connection represent the real earth grounding?
3.   Does the all grounding can be connected together to the same point?
4.   Does the HV frequency depend on the transistor switching frequency?
5.   Does the output (load) connector are represent by + and - ?
6.   Does the base transistor switching frequency triggering output frequency?
7.   Does the capacitors  (+-+-) have any resonance frequency requirement
8.   Dose the magnifying efficiency depends on the capacity of the intermediate capacitor (between transistors)?
9.   Does the system can satisfy self output adjustment according to load and induced intermediate capacitor charge?
d.
1. Yes (in resonance)
2. Yes
3. Yes
4. if you mean flyback blocking generator transistor, then yes. by the way all system are coherent
5. No, this is input (in this setup load are not represented)
/there are two inputs HVoltage HFrequency and LVoltage LFrequency/
6. Yes
7. No, they are 16v 1000uf - filters
8. Not really
9. No
Keep your chakras opened :)
cosmoLV
Quote from: grizli on October 02, 2010, 05:22:46 PM
these arcs in turkey are only for demonstration purpose, device work withot these arcs.
actual sparkgaps are in little boxes near device and are silent.
Tesla coils are connected with bobbins (Aluminum towers) but in demonstration Tesla coils are disconnected â€" this is only for visual purpose, it can work with sparkgaps and without.
actual sparkgaps like i said are in little aluminum boxes near device, they are three by each phase one.
this is three phase generator by the way...
Anyway this 100kw device are complicated, more you need power then schematic goes more complicated and expensive
dole
Quote from: cosmoLV on October 02, 2010, 07:54:48 PM
So far so good
0.  Does the process producing standing wave?
1.  Then I may guess that the output is achieved by the separate pickup coil connected to same ground connection (from experience this way should not release any significant change on input). If not I suppose many would be interesting in direction, at least the theory.
2.  If this fits correct does then the output has to be achieved inductively
3.  or directly from pickup coil and
4.  does the energy dissipation magnify the input
5.  or has to be separately lead back?
d.
