cosmoLV
Quote from: dole on October 02, 2010, 09:10:37 PM
So far so good
0.  Does the process producing standing wave?
1.  Then I may guess that the output is achieved by the separate pickup coil connected to same ground connection (from experience this way should not release any significant change on input). If not I suppose many would be interesting in direction, at least the theory.
2.  If this fits correct does then the output has to be achieved inductively
3.  or directly from pickup coil and
4.  does the energy dissipation magnify the input
5.  or has to be separately lead back?
d.
0. No
1. Yes, by separated pickup coil, but this schematics was i provided are for experiments â€" actually i already publish different parts of experimenting setups by the time... There is a problem, i try to hide some important part of it (you need to understand it) but you also need to realise that there actually are mixed two current potentials, one are switching other injecting (or correctly â€" help for work) i trying represent the idea - or turn of thinking.
and at last, this is not my device but SR device, so I'm not the inventor of it - and anyway, all thanks belongs to him.
2. better is saying magnetically, like electric generator...
3. - 2., 1.
4. i want to not answer on that - not now..
5. - 4.
Offtopic:
i hear or read somewhere that flying saucers have a very strange sound, something within a high and low frequencies - i do not know jet how to make something levitate i wish to do that, but, my theory is that there are using bunch of frequencies mixed together in very smart way.
i think the principle of Free Energy are not so far away of that.
once Tariel say, that he has lifted heavy materials as Hutchinson did - and only then he get to Free energy device, so... That i think the principle are way close - i spend about two months to find out that thing, but one thing is to move objects as Leedskalnins did and other thing is making a directions of levitation.
all what i want to say, that this device not ends on free energy, it make big shift in science and change dramatically the face of this world and it newer be the same after it comes to public.
When it happen, i only can guess and what happening then i also (and everybody) can guess...
Keep your chakras opened :)
core
Just wanted to update where I am at. My ferrite has still not arrived and I do not expect to get it for another 2 - 3 weeks. I ordered from 3 locations globally. Having said that I cleaned out a local 'Radio Shack' of small toroid coils about 15mm in diameter just to get something started.
My setup is as follows:
    - 12 volt battery. (everything runs off the battery)
    - Neon sign transformer 12VDC / 2000VAC 10ma
    - 12VDC to 110VAC inverter 150watts 60hz
    - 110VAC / 24VAC transformer 20 VA 60hz
    - 110volt rated / 25 watt light bulb
    - Spark Gap is 12 gauge copper wire
    - Ground is pure earth (not panel)
    - My coil, as per Cosmo's drawing, is wrapped with speaker wire (Bifilar fashion). Load coil is also wrapped in bifilar fashion.
  Hanging from one end is a steel washer to check magnetism. Know Cosmo spoke of 12 volts 50 hz in the low voltage coil. The closest I could get with what I had on hand was 24 VAC @ 60 Hz.I tried to pump the 110 Volts @.75 amps through the coil but the inverter did not like it. Hence the 110 volt to 24 volt xfr.
     I have to say my results where less then exciting. :( Cosmo spoke of a sound when placing a magnet next to the coil. After energizing everything if I place a magnet net to the coil the only sound I hear change, slightly, is the spark gap. The spark gap appears to get slightly noisier. Wit my current setup it is very difficult to get the ferrite core to magnetize in a manor that it has the strength to pull the steel washer toward it.
    The only way to get the ferrite magnetized to pull the washer is to almost create a dead short on the coil. Even with an almost dead short that is substituting a 20 ohm 6 watt resister in place of the bulb the high voltage is not enough to 'De-Magnetize' the ferrite rings.
   In the end, with this set-up, there is no way to de-magnetize ferrite with a high amperage load passing through it. The pictures below show the set-up.
  When the new ferrite show's up I will re-run the setup again and re-test.
Respectfully,
Core
***EDIT***  Images re-sized by Moderator.  Please post no larger than 800x600.  Thank you.
core
Additional
***EDIT***
Once again, please post no larger than 800 x 600.  The Moderator is getting tired of editing these photos to fit this page.  Thank you.
core
Note to 'Core' do not upload such HUGE pictures. My apologies to 'Pirate88179' - Mod.
BTW - Do not speak ill of 'Pinocchio'
With Levity,
Core
Pirate88179
