0 Members and 216 Guests are viewing this topic.
core
Quote from: Shokac on October 03, 2010, 05:29:35 PM
New SR Video
http://www.001-lab.com/001lab/index.php?action=dlattach;topic=181.0;attach=11928
So what is it:
(A) He ran out of wire half way through?
(B) The windings shift direction half way through?
Looking at the video it doesn't look like they change directions.
Respectfully,
Core
kooler
i know nothing of this setup..
but the spark i saw in the video..
the reason you don't hear it is that it is too high of a frequency..
Pirate88179
Quote from: kooler on October 03, 2010, 11:25:18 PM
Exactly!  That was what I was thinking.
Pinoy_Tech
@ all,
It’s my first post, I hope I am welcome here! I would like to grasp this opportunity to thanks the admin and moderator of this forum for allowing me to be a member of this group.
@ Cosmo,
Sir, I made a simple presumption diagram based on your uploaded sketch previously. I have just a few questions hanging by it. Hoping to have your little time answering my little confusions… I know you are quite busy but I can wait until you become free…..
1. Since we are using “Ferrite Core” to this device, is 50/60Hz frequency is suitable enough for the primary windings to induce power to the output coil? Is it not better if we will use a higher signal like many Switch Mode Power Supply does, probably in KHz range? What I observed now is an overheating power supply, it even blown the thermal fuse of my power transformer.
2. Those two Electrolytic Capacitors connected in series on terminals + / - , (the one you say filters), is the center part of that connection is “connected to ground” to work like a split psu? What I understand is that, the circuit is not in complete path if it is not connected to a common gnd.
3. Is there any “specific waveform” needed for the HV output? I tried HV using car ignition coil and I made a simple circuit that has a controllable voltage output as well as the input frequency to about hz~khz range but not yet successful to neutralize the effects of electromagnet energy on the core.
4. Aside form HV and AC supply from the primary windings, is there any “other process” needed to add in order to obtain the expected OU? What we have now is High Frequency with high voltage ionizer + low frequency with low voltage supply as initial source of power.
5. I understand it clearly that the main function of the primary supply is to induce voltage to the    output coil jut like any other ordinary transformer does, but what I don’t understand is;
   â€¢ how it will produce an output more than the input? If the HV is working like an interruptor, exciter, relaxer, stimulator, pressurizer, levitator or whatever function that makes the core something very special like zero point source of energy, then what is something very special on HV? A waveform, frequency signal to about 20Khz, voltage output of about 5KV?
  • Or an oscillation of the HV coil is something self-oscillating using its own feedback exciting coil?
  • Do we need to customize the HV transformer?
  • TV HV(HOT) is a sort of DC output because there are ultra fast recovery diodes incorporate internally, sometimes we called it Tripler or quadrupler. Is that TV DC HV flyback possible to use in this device?
Thanks in advance........
        Respectfully,
<jronel / Pinoy_Electronics>
core
   One more note based on yesterdays experiments. Prior to going to sleep I figured I would give it one more shot. This time I held the magnets North and South pole parallel with the coil. Turning on the power supply you can feel the pulsating of the coil's North and South pole change.
  Note, the above affect can be felt with or without high voltage S.G. on. What got me thinking was:
(A) What if I could get the ferrite to demagnetize with the right frequency.
(B) What if half of my ferrite was demagnetized and the other side was not, or allowed to build up a magnetic field.
(C) What if a coil with low voltage hi amps where wrapped around the demagnetized section of ferrite.
(D) What if another coil was wrapped around the magnetized section of ferrite.
(E) Would this second coil have a usable output?
(F) What would be the output current?
Plenty of what if's, all to be answered with experiments.
Respectfully,
Core
