0 Members and 36 Guests are viewing this topic.
cosmoLV
Quote from: TheCell on October 04, 2010, 04:13:08 PM
Me too.
Is a magnetic amplifier a overunity device or not.
Is the nmr effect responsible for the energy gain ?
nmr = nuclear magnetic resonance
no, magnetic Amplifier are not OU and ferrite with coils are not OU but combine it together.
"Is the nmr effect responsible for the energy gain ?" - yes but with all provided above together.
you need to understand i not make schematic clear here - i mean full schematics. it is in parts..
all device is something like "parametric converter" don't mess with parametric resonanse - this is my fault in early posts. i do not hawe so strong technical language and all this terminalogy...
Keep your chakras opened :)
The puzzle finally becomes clear. If you have a high voltage that can saturate the ferrite with less energy than an equivalent low voltage low frequency coil. Then that is exactly what you need on the secondary part to collect the magnetic energy as the domains relax again.
What's still a mystery is why the high frequency. I think it's because a single high voltage discharge is not enough to align all domains, you need many pulses. If you need 100 high voltage spikes to completely saturate the core then in the secondary this is when the low frequency current must be at maximum. Because now core is fully saturated and secondary can discharge slowly with much more energy than was needed to saturate it. E=0.5*L*I^2
However I made many stupid mistakes in the past so I am probably completely wrong.
Thanks cosmo for the guidance.
Shokac
If you look in detail 100kW Kapanadze setup, then we can see the following:
(http://www.youtube.com/watch?v=_CRkDySQCSM)
1. The voltage at the entrance of the system is 220 (x3), current 0A (blue cables)
2. The voltage at the output of the system is 220 (x3), current cca. 10A (x3)
System need Voltage, but no need current.
System produces current, no voltage.
And if you take the help of Cosmo......
p.s.
Analysis of the parametric converter
Sen, P. K.; Fam, W. Z.
IEEE Transactions on Industrial Electronics and Control Instrumentation, vol. IECI-26, May 1979, p. 93-98. Research supported by the National Research Council of Canada.
    The operation of a parametric converter which transfers electrical energy from the input to the output circuit by means of parametric oscillations is analyzed. The analysis of this highly nonlinear device is based on two main functional relationships which relate the flux in each of the two iron cores to the MMF's of the input and output windings and utilizes a fifth-order polynomial to describe the magnetization curve of the built-up magnetic structure. Expressions are derived for the currents in the converter windings, the parametric power transferred between the two circuits, the input power factor, and the required tuning capacitance.
cosmoLV
broli:
all humans make mistakes, i too make mistakes - without these mistakes i not bee there where i am. (actually thanks to these mistakes)
and last, i hope nobody who replicate this device are not release it publicly - i not release this for friends and anybody, situation is very confusing and i lost lot of friends (human nature unfortunately, if you don't tell then friends run away from you like from evil) it is hard to keep it in secret, but in 2011 - this need to be release. (something around 2011 maybe summer)
this is because i communicate, i like and i hope for showing up SR and Tariel on the network.
Tariel wants a money for its device, but i talked with him and i say him - this is not the way how to integrate device - device need to be integrate with help of comunity - all together but in the same time it not need to be integrated with schematics - this is little bit dangerous, because military background... there are lot of things going on around this device and all facts showing that military organisations don't know how to get free energy, they only manipulating about information and they do not know how to flying saucers work... So think: (it should be released publicly? i think no... this device need to be integrated by DressCode) or military sector have unlimited power to destroy planet â€" because there are too many sick peoples who monitoring whats happening and they want to control humanity and we all know that system what is now are totally wrong and don't have any humanity to humans...
http://translate.google.com/translate?js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=0&sl=ru&tl=en&u=http%3A%2F%2Fwww.dieselloc.ru%2Fcircuit%2Fte10_7.html
LtBolo
Quote from: cosmoLV on October 04, 2010, 04:30:04 PM
If it is truly a parametric converter, which based on what I've seen is possible, I can easily build a case why resonance is not needed. The currents in the spark can easily go to several hundred amps or more, and according to 0.5*dL*I2, a high current is more important than a big delta L. It's not too hard to build a math case why a 0.1 joule spark could become 0.2 joules or more of extra energy at the output coil. Do that repeatedly, and you can produce significant amounts of real power.
