0 Members and 28 Guests are viewing this topic.
LtBolo
Thinking about the relationship between the inner coil with an external core and the outer coil with an internal core. I'm not going to draw it up...think about it yourselves...but...it looks like some interesting things might occur as the core goes resonant and forces the magnetic flux elsewhere. The charging configuration and discharging configuration would be very different. Still pondering the implications of that, but it appears to me that some stuff would be in phase that normally would not be.
Shokac
core
Quote from: LtBolo on October 05, 2010, 11:40:21 AM
Hmmm... This got me thinking of a Tube in Tube heat exchanger. Thermal energy is allowed to pass via the copper tubing due to the difference in energy levels (heat content). I enjoy your thinking. :)
Respectfully,
Core
starcruiser
I believe we need to think about Torsion fields/waves. Copper mass, HV sparking to generate torsion fields using a Bifilar coil to cancel the EM component and a way to capture and convert back those Torsion waves from the copper mass (another coil).
you have all the components in the design already, the 12ga stranded two overlapping coils, one is smaller to allow the coil to generate a small bias field (EM), the larger copper (5 or 6 turns) is the capture/converter. The core needs to be copper mass to amplify the torsion field. Move the 6 turn coil to the far end of the core away from the second coil, this 5 turn or so coil may overlap the first but should allow us to capture the torsion field and convert it back to EM thus allowing us to use it.
Gotta try this out....
Regards,
Carl
core
To take the energy exchanger theory one step further. Ideally the higher energy flow is on the inside and lower on the outside. Also they flow in opposite directions. So where the low energy mass enters the heat exchanger the high energy mass exits. They are opposing each other, this maximizes energy transfer.
Some food for thought.
Respectfully,
Core
