0 Members and 28 Guests are viewing this topic.
cosmoLV
Quote from: core on October 05, 2010, 01:47:39 PM
To take the energy exchanger theory one step further. Ideally the higher energy flow is on the inside and lower on the outside. Also they flow in opposite directions. So where the low energy mass enters the heat exchanger the high energy mass exits. They are opposing each other, this maximizes energy transfer.
Some food for thought.
Respectfully,
Core
Quote from: LtBolo on October 04, 2010, 06:23:32 PM
If it is truly a parametric converter, which based on what I've seen is possible, I can easily build a case why resonance is not needed. The currents in the spark can easily go to several hundred amps or more, and according to 0.5*dL*I2, a high current is more important than a big delta L. It's not too hard to build a math case why a 0.1 joule spark could become 0.2 joules or more of extra energy at the output coil. Do that repeatedly, and you can produce significant amounts of real power.
There are great explanations, keep focus on that.
Quote from: catalyst on October 05, 2010, 10:13:55 AM
I have few remarks/comments/etc.
About shielding:
Is it meant that the coils are to be outside and the other related electronics inside a shielded box ? Is this the reason for an aluminum briefcase in the recent photo from cosmo? As also with Kapanadze video's green box ?
About Donald Lee Smith's designs. Look at the phrase used there @ http://www.free-energy-info.co.uk/DonSmith.html
Donald says his device is heavily commercialized, yet i can't find anything in Google.
"However, he says that he discloses enough for somebody who is experienced in radio-frequency electronics to be able to deduce the things which he does not disclose and so build a device for his own use. If that is the case, then anybody who has succeeded in doing so has kept very quiet about it afterwards (which is understandable). Having said that, Tariel Kapanadze of Georgia appears to have replicated one of the designs although it is quite likely that Tariel deduced the operating principles for himself. These principles are clearly based on the work of Nikola Tesla."
Tariel may not be the 1st one, since Donald was there in 1994 with very same design it looks to me.
This design says it all or not ?
http://www.free-energy-info.co.uk/DonSmith/Don27.gif
If this is correct, then the 6-turn big diameter coil L-1 is connected to HVolt/HFreq (like 8KV/35KHz).
"L-1 and L-2 coils are now present. L-1 has a smaller number of turns and is several times the diameter of L-2. Input from a 12 volt high-voltage laser driver source, produces 8,000 volts with a low level of wasted energy, pushing amperage into, say, 4 turns of coil L-1. Each turn of the L-1 coil then acquires 2,000 volts of resonant potential. Consequently, each turn of L-2 is then exposed to the electric flux of 2,000 volts. Each turn at the bottom end of L-2 acquires 2,000 volts. The flux lines are squared and are additive as the voltage and amperage progresses towards the top end of L-2's large number of turns.
A huge number of additional flux lines which were not previously present become present at the top end of the L-2 coil. These flux lines excite the nearby electrons in it's earth and air and groundings. This high level of excitement above the ambient, causes a large number of electrons which were not previously a part of the energy present, to become available for use. At this point over-unity is present in large amounts."
About the dark forces:
Only if this type device and knowledge is publicly known (like Vladimir Utkin does as example), it can break the grip of TPTB on people like us gathered here. The elite ("The Gods") has unimaginable more info and tools and gadgets as we can ever dream. Internet is only medium that may derail them.
To tell the truth, what Tariel did is not the right way. He wants mainly money out of it. He will have it, but not this way by patent. This way to go means to go along with the current system. Free energy (i say it comes from "freedom", and not "for free" or "no money to pay") was suppressed by the powers to build up the current system and control/lock us inside it. The spread use of OU device maybe derail it. So it makes no sense to swim with them and piss in the same pool. Better is to release it in public and collect the respect. In nature, there are no patents, no money, no electric from the plug in your wall.
i connot imagine smith device as Free energy generator - Smith has done a big job, but there nothing smells from Free energy
QuoteAbout the dark forces:
Quote"has unimaginable more info and tools and gadgets as we can ever dream"
What is gadgets without knowing what to do with it? and why these forces are so interest about tariel and asked him the technology - from USA to Arab emirate forces - i think they not know how to work device :)
Keep your chakras opened :)
LtBolo
A ferrite core on the outside of a coil has almost no effect on the inductance, and as such, would be nearly impossible to saturate from the inside out...that says the saturating coil must be on the outside. So far, I'm not seeing much effect on the inside coil, no matter what I do, but clearly somebody thinks it's useful.
dllabarre
Cosmo
On the attached schematic, which coil is the one that you have inside your ferrite core?
Thank you,
DonL
cosmoLV
Quote from: dllabarre on October 05, 2010, 04:08:24 PM
Cosmo
Thank you,
DonL
in this schematics inside coil are not provided
TheCell
Regarding the magnetic amplifier sparkbangbuzz.com :
using the two transformers with their HV windings connected that way the HV voltages cancel each other, while applying a small dc voltage to them modulates the impedance of the whole thing.
(resulting in a dc current that drives the core into saturation)
So if we modulate this dc voltage with the nmr frequency of the iron should this enable the nmr effect (nuclear magnetic resonace).
Is this frequency 21 MHz ?
What type of core should we use to prevent remagnetization losses ?
What use has a spark gap in this setup anyway?
