0 Members and 94 Guests are viewing this topic.
core
Quote from: Pirate88179 on October 05, 2010, 08:05:25 PM
Core:
Nice toroids.  Hey if the Kapanadze device experiments do not work out, if those are high permeability toroids, you can make some very powerful Joule Thief circuits out of them.  Probably close to 2,000 volts from a single AA battery.
I look forward to seeing your results.
If Kapanadze experiments don't work out expect to see a box of toroids at your doorstep.
Respectfully,
Core
forest
Quote from: cosmoLV on October 05, 2010, 08:05:08 PM
1. No - it comes from changing parameters of ferrite medium
2. yes, but not so critical
3. i do not have info on this - (can you provide link on that information?)
4. No
1. you are talking about a method ? does it have a relation to this http://www.greenoptimistic.com/2008/02/06/the-isotopic-electricity-generator/ ?
but again it may be just a additional effect imho, like carbon brushes against copper brushes
2. thanks
3. from 1897 till probably around 1920 Tesla patented many circuit controllers to get fastest possible make&break then stopped  ::)
4  Edison etheric force, McFarland Cook patent and many forgotten patents, not directly the same but hey that was different times  ;D
exnihiloest
Quote from: TheCell on October 05, 2010, 04:54:59 PM
So if we modulate this dc voltage with the nmr frequency of the iron should this enable the nmr effect (nuclear magnetic resonace).
Is this frequency 21 MHz ?
A nmr frequency is depending on the static magnetic field which must be very uniform in the whole material. Otherwise the frequency is spread on a very large band (tens of Mhz) and no resonance can be observed.
http://rmn.iqfr.csic.es/guide/eNMR/chem/Fe.html
@Cosmo
In the magnetic amplifier article the author mentions a trick to get rid of transformer action in the setup by using two transformers out of phase in series. Is this trick very important?
