0 Members and 139 Guests are viewing this topic.
catalyst
Quote from: dllabarre on October 06, 2010, 12:11:03 PM
Can someone please translate the Russian in these pictures?
I'm curious even though they may not be relevant.
Thank you in advance.
DonL
Is this related with ferrite rings ? Are the ferrite rings isolated from each other ? Is there a step up gain of something and it's timing that is described in that diagram ?
DimaWari
Hi guys!! I would like to add this to shokac post.. Its about switched bifilar parametric
http://jnaudin.free.fr/html/parabifc.htm
catalyst
Sorry if i can't hold my horses here. I have run thoughts about the possible construction of the coil.
What is the purpose of ferrite material anyways ? Won't it act as better medium than air to concentrate the flux lines within it ?
From Wiki:
"Ferromagnetic-core or iron-core inductors use a magnetic core made of a ferromagnetic or ferrimagnetic material such as iron or ferrite  to increase the inductance. A magnetic core can increase the inductance of a coil by a factor of several thousand, by increasing the magnetic field due to its higher magnetic permeability. In electromagnetism, permeability is the measure of the ability of a material to support the formation of a magnetic field within itself. In other words, it is the degree of magnetization that a material obtains in response to an applied magnetic field."
L-1 is the low turn count, low amp, high frequency, high volt coil. This is the aggressor. The electrons move on surface of the coils copper wire. Thus we have a fat wire selected here i assume. So that the electrons have more surface to move on it.
L-2 is the high turn count, high amp, high frequency, high volt (divided by turn of L-1) coil. This one due it's higher windings count, produce additional flux lines.
Tariel design put L-1 on outside and L-2 inside. In SR/cosmo design it seems this is opposite. My thoughts went like this:
L-1's flux lines in center have no effect, since L-2 is on outside. Since L-1 was placed inside ferrite rings, then the outer flux lines of L-1 will bundle together through the ferrite rings ? Since the ferrite rings are in the center of L-2, then L-2 will get activated through the"outer" flux lines of L-1. Is this correct ? Do i have any mistakes so far ?
The magnetic field of L-1 can further be increased by inserting a rod into L-1.
baroutologos
CosmoLV said
schematic what i provided not give a OU in any way, this is only for experiments - for start and seeing how effects are produced in combination of two potentials.
There is process of "Magnetic Amplifier" who played important role in setup.
HV part have two contours
LV have two contours and these contours are Magnetic amplifier and ferrite part. (if we go little bit deeper)
Stimulated by the above (besides i always wanted to do that experiment), i arranged Nyle Steiner's magnetic amplifier's proof of concept work. After some tinkering with my setup i was able to grasp how the LV DC side controls the inductance (by saturating cores) thus altering the impedance hence the output of the AC high power side.
My typical current gains were 1:10 to 1:15, bulb is 20w.
http://www.youtube.com/user/baroutologos#p/a/u/1/otHbjZPrHXE
Next i am making the ferrite LF LV AC electromagnet and HF HV AC supposed electromagnet canceling properties CosmoLV suggested
Pirate88179
