0 Members and 117 Guests are viewing this topic.
core
Quote from: cosmoLV on October 07, 2010, 02:11:10 PM
try to modulate your coil with some frequencies
see what happen with applyed HV and without HV
place near coil magnet to hear a difference
just take my first experiment setup diagramm, and where are AD or DC coil apply there some frequency, like 100 hz - 21khz and above
do it with HV and Without HV and if you placed a magnet you will hear the effect
, i'm not believe that it has no effects - i just know it 100% because i doo experiments  24 hours a day at 7 days at week, and so on...
Got it.
   So that we are on the same page here. Understand that when you start talking about creating a signal with different frequencies I got to do some thinking and homework. I most likely know less about electronics or that aspect of electricity then you do.
   Now if we where talking about Specific Density, Grains of Moisture per pound of dry air, Enthalpy, Specific Volume, Compression ratio's, and proportional drives then we would be on the same page.
   I'll do some homework and report back.
Respectfully,
Core
LtBolo
Quote from: core on October 07, 2010, 03:51:00 PM
(B) It's my understanding the Bifilar makes a stronger magnetic field.
Yes and no. If you hook both bifilar windings up in the same direction in series, then perhaps...although I haven't personally proven that. If you hook them up in opposition, they cancel and you get capacitance but almost no magnetism.
@core:
You shouldn't hold your compass that close to your ferrite. The changes might be minute, but you won't tell since the compass is so close. Put it a little farther so it has a chance to react to any small change. If you then see nothing then there's a problem. I doubt you have a scope or a hall sensor.
PS: Happy birthday cosmo.
baroutologos
Hey, why you suggest to modulate the coil with frequencies? This mean the plain AC or DC as you initially suggested is not going to work?? Why is that?
And how to modulate with frequencies up to 20Khz? Transistorized? I have fully verify that transistors go wild by the application of a working spark-gap.
So you cannot tell for sure if you are observing a weird phenomenon or the change is due to running circuit malfunction..
Mito Kupona, Tiger, Madsatbg and me have seen that in action giving the impression of something happening. (in inverter setups 50 Hz as forums suggested. I proved this falseness by running the inverter pair not by signal generator or 555 but from a small mains step-down transformer)
ps: Actually not the transistors but the timer circuits that control them.
ps2: Biffilars are not creating any stronger magnetic field for same input. It has been checked again and again.
Magluvin
Two reasons:
(A) I got LOADS of speaker wire that make it easier to roll.
Respectfully,
Core
Hey core
Speaker wire will work, and it reduces coil capacitance by having more space between the windings. And high frequency likes more surface area, and stranded wire does that well.
Bifi will give a stronger field than a normal coil of the same amount of wire. Good luck
Mags
