0 Members and 165 Guests are viewing this topic.
ramset
Marco
Sir,
Can you make /offer any suggestions on how to proceed?
Perhaps a direction for experiments?
Thanks
Chet
Thanks Grandma
turbo
well you first have to make sure that you understand the concept of a virtual ground.(the anti weight)
turbo
Then this is the basic principle.
You can place recievers anywhere around the globe.
Yucca
Quote from: flathunter on July 16, 2009, 05:34:34 PM
I'm wondering what happens if you tune it like this, and then try wireless transmission with a receiving coil.  Will it work?  what do you think?
Hi flathunter,
I would think it would definitely work provided the TX and RX coils were matched well. When you do wireless TX using antinode at top (conventional tuning) you have an electrical capacitive coupling between TX and RX top loads. But in this case you would have a magnetic coupling between the two coils, no top loads required.
Provided you keep within near field distance the power you're able to transfer should be pretty good. in this near field calculator the "largest dimension" would refer to the physical length of the secondary, not the wire length but the length of the coil cylinder:
http://fmuser.com/Download/Antenna-Field-regions-calculator.html
My guess at the moment though (looking at smiths open coils) is that power is extracted by the primary (how exactly I'm not sure). But you'd probably need real fast diodes with very high voltage tolerance and really low ESR caps for collection like doorknob caps.
If you don't couple to the secondary oscillation quickly then the oscillation will soon turn to fast (approaching C) mag propogation (Radio waves) especially outside the near field distance. Be careful with this because you can get RF burns, if you start to feel prickly face skin etc. then try to shield experiments in a grounded cage until you can effectively mop up the mag emmisions before they get too fast and turn to RF.
Good Luck! Yucca.
