0 Members and 145 Guests are viewing this topic.
dllabarre
Quote from: cosmoLV on September 27, 2010, 11:04:14 PM
core - i recommend these: http://cgi.ebay.com/Toroid-Ferrite-Cores-M2000NM-44x27x8-USSR-89-QTY-12-/310217966008?pt=LH_DefaultDomain_0&hash=item483a6e81b8
you will need 19 to 24 of them, but 12 for tests are great
Cosmo,
I can't find these Toroid Ferrite Cores M2000NM 44x27x8 (USSR-89).
Is there any other size and quantity that would work as well as these?
Thank you,
DonL
Shokac
Quote from: cosmoLV on October 08, 2010, 12:49:43 AM
if you have anaglyph glases Red-Green (red on left side)
there can bee seen interesting things how are connected bobbins with TeslaCoils ;)
Magic answer is GLAS.
http://www.hvlabs.hu/zpe/DonSmith/Don-Smith-Device-2006.pdf
But if you look at all Kapanadze coil (even a small coil at Cosmos pictured), in each of them is paramagnetics material.
Polymer clay, polyurethane foam ...
romerouk
baroutologos
I got out the 10kV transformer and used it on the HV side.
It almost completely killed the magnetic field.
The compass just barely moves.
The spark gap was so loud I couldn't hear any change in pitch.
So someplace between 2kV and 10kV is a good number.
Cosmo said 4kV is enough and it appears he correct again!  8)
DonL
Hey Don,
Can you specify your setup? Can you provide photos and some rough figures outlining the experiment? After all it is an experimental thread. (apart from theoretic)
dllabarre
Quote from: baroutologos on October 08, 2010, 06:13:46 PM
Hey Don,
Be warned.  It's nothing like the quality builds you produce.  :)
