LtBolo
core
Quote from: LtBolo on October 09, 2010, 05:30:54 PM
Is any one else confused by Ansis' post?
I don't know.
   At first I thought he was just a loon but the line about interfering HF with LV is dead on. Also another thing that makes sense is that SR's device, contrary to what Cosmo says is not even in the same ballpark with Tariels. I believe Tariels device is unlimited and SR's is very limited.
   Somehow I just can't see how Tariel gets 5KW out of that small green box and Cosmo and SR (perhaps) can only pull off 400watts? Something does not sound right to me. It appears that everyone, including our Russian counterparts, are being 'pushed' into doing it the SR way. Every thread everywhere that has been started about Tariel's device has been directed toward using ferrite rings and the SR method, why? SR has never built a 5KW unit out of scrap wire and I bet he doesn't use a steak knife as a wire cutter and stripper. I don't think I even saw a solder joint on Tariels device.
   Why are we going in this direction??????
Respectfully,
Core
BTW - Found some great hi-voltage drivers on the internet. In the process of building them as I type.
LtBolo
Quote from: core on October 09, 2010, 06:28:31 PM
Simple. Because anything greater than about 150% can be scaled up to meet demand, maybe even 125%. At 10x you would be drowning in power.
And for what it's worth, this approach to using ferrite is probably the least efficient way it can be done...but...done properly this way, it will provide it's OU on a spark by spark basis without any resonance requirements. I'm still thinking the more efficient way would be to use a tuned high Q secondary, it's just much harder to build.
Changing subject...I have played quite a bit with various coil configurations on the inside of the ferrite. I feel all kinds of vibrations in the ferrite...but I cannot get any real power in any coil configuration. Really wish Cosmo would enlighten us further...
core
Quote from: LtBolo on October 09, 2010, 06:56:53 PM
  Somewhere along the line there is a process of mixing two waves a High and low voltage to make on. Flip back about 15 to 20 pages and I think you will see what I mean. Until we get to that point I don't think you will see any power amplification. But you do have an amazing hot dog cooker. :)
Respectfully,
Core
core
  I would like to know if Cosmo also gets a amp reading on his ground wire. It looks like, and maybe I saw it wrong, that Tariel was getting 22 amps on the ground wire. Maybe I saw the wrong wire. How would that work with a GFI?
Respectfully,
Core
