0 Members and 580 Guests are viewing this topic.
Dankie1
Quote from: core on October 09, 2010, 06:28:31 PM
I don't know.
   At first I thought he was just a loon but the line about interfering HF with LV is dead on. Also another thing that makes sense is that SR's device, contrary to what Cosmo says is not even in the same ballpark with Tariels. I believe Tariels device is unlimited and SR's is very limited.
   Somehow I just can't see how Tariel gets 5KW out of that small green box and Cosmo and SR (perhaps) can only pull off 400watts? Something does not sound right to me. It appears that everyone, including our Russian counterparts, are being 'pushed' into doing it the SR way. Every thread everywhere that has been started about Tariel's device has been directed toward using ferrite rings and the SR method, why? SR has never built a 5KW unit out of scrap wire and I bet he doesn't use a steak knife as a wire cutter and stripper. I don't think I even saw a solder joint on Tariels device.
   Why are we going in this direction??????
Respectfully,
Core
BTW - Found some great hi-voltage drivers on the internet. In the process of building them as I type.
I have the same feeling , on the russian forums SR is mostly ignored now .
Lets not put insis comments in the trash bin right away .
LtBolo
Quote from: core on October 09, 2010, 07:26:53 PM
  Somewhere along the line there is a process of mixing two waves a High and low voltage to make on. Flip back about 15 to 20 pages and I think you will see what I mean. Until we get to that point I don't think you will see any power amplification. But you do have an amazing hot dog cooker. :)
I don't know if I agree with that. If the amplification comes from parameter change in the ferrite, then I am already getting it, but not using the configurations that Cosmo claims. When I stick coils in the center, I can feel vibrations in my fingers when I hold them just off of anything connected to the coil...without actually touching it.
When I use a more traditional primary/secondary approach, I can light a 150W halogen rather nicely when getting good discharges that I know are saturating the ferrite, and not at all with the same power not properly discharged. The problem right now is that I don't have any good way to quantify the amount of power actually going into the primary vs the amount of power coming out of the secondary. It should be pretty simple...but due to the insane voltages and very narrow pulses it is pretty difficult to get a fair accounting of the powers. But from what I can see, the key to this seems to be to get the power out before the parameter changes back. Given the very high speeds of the pulses and relatively short duration of the saturation period, that seems to be a little harder than you would think.
That said, if ya'll got any clues how to do this better, I'm listening. I'm still thinking that a Tesla transformer is boosting voltage kinetically, and if you were to find a good way to interact electrostatically with the business end and build a high current resonance from that relative to a distant ground, you might be finding the common ground between Kapanadze and Smith. I don't put too much stock in Smith though...
core
Quote from: LtBolo on October 09, 2010, 08:36:46 PM
  Just as a wild a$$ guess. There was that YouTube video of the man Madog? (I think I got his name wrong). He places a ferrite rod with a coil wrapped around it soldered to a light bulb. If you do that in you setup will it light?
Respectfully,
Core
BTW- are you pulsing the primary coil? Is that how you are saturating the ring? Are you able to nullify the magnetic field with the hi-voltage?
LtBolo
Quote from: core on October 09, 2010, 09:02:26 PM
Yeah, but for different reasons. His is in a tesla secondary...an electrostatic field and the ferrite becomes an antenna. I'm not sure what we are dealing with in the saturated ferrite case, but adding more ferrite just moves the magnetic field inside the inside coil. I would fully expect it to light. The best light does not come that way.
There's nothing to nullify...I'm not powering the secondary. I'm not sure why you would even want to. The amount of current being induced in the secondary as the primary is saturating the core is 2 orders of magnitude higher than what you would be powering secondary with.
I think cosmo was just trying to show that a spark discharge could kill the magnetic field by resonant saturation...nothing more.
Incidentally, the only time I can light the bulb is when I am certain the core is saturating, as verified by scope traces like the one I posted many pages back. If I don't get that waveform, the bulb doesn't light...that's what leads me to believe that I am already getting the desired effect. Just can't do it from inside...
dllabarre
Can you post the link to the high voltage dividers?
While I was driving today I was thinking "if I could divide up my 10kV transformer output I could use it for this device".
I get home tonight and read where you found some HV dividers.  It's like you caught my thought this morning.  ;D
Thank you,
DonL
