0 Members and 1844 Guests are viewing this topic.
catalyst
Collect all this together:
This is cosmo's coil setup:
http://img508.imageshack.us/img508/4952/rtgxsgvypa.png
This is magnetic amplifier:
http://www.overunity.com/index.php?action=dlattach;topic=7679.0;attach=48038;image
This is our best schematics so far:
http://www.overunity.com/index.php?action=dlattach;topic=7679.0;attach=48135;image
The LV part:
NPN,PNP emitter followers, 2 bifilar coils and the extension coil
Take the magnetic amplifier diagram. Imagine both coils connected together over one ferrite. The 35V 2700uF cap corresponds to the 9-12V DC battery. We need to add one poti to our schematics, same as it exist on the mag amp. The bifilar coils are equivalent to the secondary windings in mag amp, in opposite direction. The AC source in mag amp schematic is generated from 12V DC using the emitter followers. We have no lamp, because we do not want to burn electrons here, only generate magnetic field!
In each hi and low state of the input clock signal, the magnetism reverses.
Now look in cosmo's coil setup. The HV/HF blocks the primary (not needed by us, it would disturb, that's why it's placed above HV coil). The secondaries (i mean bifilar windings) are under the HV coil. Because we want magnetism NOT blocked by HV/HF coil. On top of it since HV/HF coil is tuned to be super magnet, we get extra boost (OU). That's it mystery solved.
This is so to be said a power generator, not mechanic, but fully electromagnetic!
Nobody blame me, i just connected cosmo's dots together. It's public anyways. Full credit goes to cosmo!
catalyst
Quote from: core on October 14, 2010, 12:30:33 AM
My question is:
'If the HV/HF being active removes electromagnetism then how does HFreq make super magnet if at the same time it removes electromagnetism'?
You're right. When i wrote that text, i was not done yet. Like a JPG image, the compression was too high. :-) Read my last post, then all is clear. The right info is that HV/HF is ON always (never turned off) and due coil winding you extract the effect you want. You get supermagnetism, you get flipping magnetic field, you get rid of the unwanted effect of primary winding of magnetic amplifier, by simply putting that part above HV coil (you know HV coil disables magnetism on coil above it!) etc...
Shokac
I agree with Catalyst, only I think the coil is not Cosmos coil. Coil is nothing but a DC-AC transformer with HV coil inside or outside.
If the HV is off, lamp illuminates very weakly.
Look at first lamp illuminates of Kapanadze video. (Only DC to AC converter without OU (HV))
HV give Juice (OU) on ferrite!  :)
ramset
Please keep your "images" small, so we don't have to scroll to read the page!
Chet
Thanks Grandma
