0 Members and 136 Guests are viewing this topic.
baroutologos
hello Don,
Yes, the transformer is rated at LV side 12VAC. If you count and the voltage drop it would be some 11,5 at transformer's leads.
The ignition coil can output serious voltage in appropriate tune can reach up to 20Kv. But I am experimenting with gaps in the SG ( as you see in the photo) between 0.5 and 2mm.
So far no result. In your case what did you observed?
dllabarre
Quote from: baroutologos on October 17, 2010, 11:01:24 AM
hello Don,
My LV was straight 12V, light bulb, coil.  Not pulsed so I had a strong magnetic field.
When I turned on the 2kV NST there was a high pitch sound generated from the coil but it didn't have very much effect on the magnetic pull of the coil.  Just a little change using a compass.
DonL
Shokac
Quote from: forest on October 17, 2010, 06:38:28 AM
What do you mean ? Getting 220V from 12V without going through inverter ?
Yes, but without going through outgoing transformer.
I need 220V DC on SR/Kapanadze coil, but without step up classic transformer.
Why is Kapanadze use Inverter DC 12V to 220V????
Is it rectifies the 220V AC to 220V DC?
Is the use of 220V AC in its coils.
Coil is a 1:1 output transformer, no step up or step down the winding. (Maybe a little. 1:1,1)
Do you try test on Cosmo? I try, at one moment during a particular frequency (HV) humming away at the core. Why?
I think we've got super core, without a return magnetic field. (Lenz low)
So I need 220V on coil!
After that I will measure the input parameters in the loss of murmurs in the core.
scorpio
Three phase motor = three coils in a box...
I can see a simply coils: one primary, one secondary
