0 Members and 552 Guests are viewing this topic.
cosmoLV
Quote from: baroutologos on October 17, 2010, 10:35:50 AM
And here we are. Today i found some time for experimenting with the experiment Cosmo described.
Procedure
I put together 17 (glued) ferrite rings 2000 Permeatability, Soviet type (40mm diam).
I wound on them one common electrical grade wire some 40 turns, and upon it some grade wire another 40 turns or less.
I took one handy transformer and put a 4amp (40w bulb) in series with the LV AC source so as to provide some 3,5 amps of 50 Hz AC current flowing from the top windings.
The bottom winding i connected it via an also handy spark-gap and to the custom made HV source i have composed of a 555 timer oscillator, an Ignition coil and a FWBR.
The particular HV source is pulse adjustably from 250 to 4000 Hz by the 555. In real terms i do not know if this is so or it speeds up by the HF currents interference as i have noticed in many respects of inverters interfering with spark-gaps.
The LV 50 Hz current of 3,5 amps is just too few to create a noticeable attraction to any ferromagnetic object at the end of custom ferrite solenoid. BUT, if i take a strong neo-magnet as Cosmo suggested the magnet tends to act as a magnifying glass, greatly enhancing the sensation of the created magnetic field around the solenoid. (my fingers still buzz)
From my setup and in any respect, i failed to perceive any change in magnetic field's behaviour by the application of the HV via the SG. I made some combinations using a ground, opposing polarities, pulsing the LV winding via a diode (one way wave), still no difference observed.
Any suggestions?
PS: I observed that unconnected to LV transformer, the ferrite solenoid is electrified and small sparks go to my finger. I measured two points of a ferrite rings and DMM shoes it has a small but appreciable conductance
PS2: I put a coil inside the ferrite solenoid.This coil is not couple inductively to the outer coils.
The whole point of ferrite saturation and Coils inductive coupling reminds me Tesla's patent No 433,702.
i`m not understand why everybody want a get free energy from this setup or even a extra energy of it  ???
this is setup to demonstrate a effect in ferrite with two potentials - i think i described it several times  :(
scorpio, this video are around for one month now, it is Three phase 20 Kv mechanic/hydraulic system - by the way, it can start 20kv generator from little 9v Battery ;)
you connot run inverter from 9v Battery (anyway, this is not so useful) but you can run HV from 9v easely - HV side is the resonant and all pushing mechanism and it is wery important part of device and after that switches other part LVoltage, Tariel use Time relay for that... SR use "UPS" simple switching electronics
Keep your chakras opened :)
baroutologos
@ Cosmo,
Are you mocking us my friend?
Who spoke about free energy in this experiment??? I said with that setup i did not observed anything at alll at all by the application of two potentials to the ferrite solenoid.
You suggested an experiment in order to observe something different. A simple step towards a potential OU device. Nothing I did observed at all. Have you anything to add in order to run succesfully the suggested experiment?
Salutes.
Shokac
@Cosmo
Do you use DC or AC in the coil?
What is the value of the voltage on the output transistors, 220V?
cosmoLV
Quote from: Shokac on October 18, 2010, 02:26:05 AM
@Cosmo
220v on output transistors? why output transistors, i have on transistors maximum 11v 12Amps - a they are not putput, there are no output transistors
Shokac
Quote from: cosmoLV on October 18, 2010, 03:14:27 AM
Hmm, the coil is not output transformer?
Output transformet is step up transformer? (large transformer in your picture)
Or a coil connected in series with the output?
