0 Members and 75 Guests are viewing this topic.
exnihiloest
Quote from: poynt99 on October 18, 2010, 08:04:37 AM
...the patents clearly show the input and output is DC.
Interesting objection, nevertheless it is not clear.  It is stated:
"First part consists of an accumulator or chargeable battery or an inverter or network or any other power supply" (patent WO2008103130A1, page 2). "Inverter" or "network" means AC.
Probably AC or DC work, at least to start up. Then, when the device is looped, the question remains open.
poynt99
Quote from: exnihiloest on October 18, 2010, 08:40:37 AM
DC can be created from an AC supply. I am sure that is why the AC references are there. Ostensibly, his devices require a DC input. In the simplest case, a battery or charged capacitor (accumulator) provides this input.
QuoteSome part of the energy generated by the device is used to feed the energy cables (14 and 15) feeding the first circuit and the power supply where this power supply needs to be recharged.
Also, no AC input is required, as the frequency generators are onboard. They will no doubt be DC-supplied.
.99
TheCell
Some of my thoughts (you may confirm or reject them)
1) without the hv winding it would be a normal stepup transformer
(12 V to 220 V)
2) The HV AC frequency is coupled via PLL to the low frequency : 50 hz
so that the HV AC is a integer multiple of this main frequency.
Now there are 2 things to experiment with:
a ) Main Voltage (50 Hz) should be high enough to create a strong magnetic field .
Saturating the core leads in my opinion only to thermal losses.
b ) varying the multiplier and notify if the output increases.
poynt99
