0 Members and 145 Guests are viewing this topic.
leo48
QuoteVery speculative, really. Too much? Plausible? What is your opinion?
Good idea but the problem is translating it into some device that provides electricity to 220v and 50 hz with a capacity of at least 5kW of power.
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
baroutologos
Quote... I opted to start at the beginning, something that deserves attention is the setup of a Tesla Coil with the addition of an extra coil in the fan community is also called as Tesla Magnifier. There are documents that highlight the strange voltage gain is obtained with this configuration.
Hey Trastos,
I suggest you read some books about Tesla's High frequency transformers and eventually read Colorado Springs notes. I personally understood that the "magnifier approach" had nothing to do with energy magnification, rather it is a engineering feat!
A classical tesla coil has to do compromises between primary coil's design for maximum energy transfer, it should it allow a free vibration of the secondary without being too much closed coupled and secondary's being made so as to provide that coupling and same time to withstand tremendous voltages without sparking easily.
The Tesla Magnifier is the perfect solution of industrial interest. At the end read Tesla's patent "Apparatus for transmiting electrical Energy" that is the epitome of oscillators.
I have made one small resembling the Magnifier and watched sparks up to 10cm with 40 watts input.
It is very very interesting piece of equipment and according to Tesla can be used for vast energy transfer around the globe, assuming it oscillates at an unknown to me frequency that the earth "responds" or oscillates also, thus not filtering the signal...
Apart from that, no FE there.
Trastos
Thanks for sharing your experiences, my idea was to see if they had something to do with the setting "extra coil" to the configuration of coils Kapanadze, because they use longitudinal waves. If you say that they are two different ways of working, I don't check this and think other possibilities.
baroutologos
You gave me an reason to expose my ideas about the longitudinal waves.
Waves in nature come in two shapes. Tranverse and longitudinal.
The Hertzian waves Tesla spoke of (and disregarded so much) is the common electromagnetic radiation that according to some is the propagation of displacement current using the ether as a medium or any  medium having electric properties thus resulting in electric and magnetic fields interchanging in each other in 90 degrees planes. As far i remember Maxwell's first try to explain those waves was based on the ether assumption.
Hertian waves is a byproduct and loss of a Tesla coil in operation. Tesla observed that those losses go almost in the square of the working frequency over a piece of wire, since the electrical oscillating energy tends to radiated as EM and lost from system as well other factors as wire's diameter etc.
Tesla strived to eliminate those loses - the Hertzian ones- by making his oscillators working in the low frequency spectrum of RF 20-100 KHz namely.
Longitudinal Waves
A working Tesla coil firmly grounded, if viewed from the electrical oscillations side, it is a pump sucking and pushing electrons in and out the earth by emptying and charging its topload capacitance.
Amperage can be considerable (capacitance x voltage x frequency).
Push-Pull EMF action produce electrical waves in the ground spreading towards all directions away from the working Tesla coil just like the pressure spreading from a syringe filling and emptying its volume to a washbowl.
Those waves of EMF inside the ground according to Tesla are longitudinal in nature and spreading faster than speed of light.
core
Quote from: exnihiloest on October 19, 2010, 04:55:23 AM
Possible theoretical source of energy of Kapanadze's device.
As said before I would prefer not to suppose a priori that there is OU and not to "philosophize" around the possible "magic" of the device. Just the facts. Nevertheless here is an exception, very speculative.
If we presume there is OU in Kapanadze's device, the simplest explanation should be the right one, according to Ockham's razor. Nobody yet succeeded in exploiting exotic sources of energy like ZPE or like Maxwell demons. We will dismiss them as well as crazier speculations like virtual photons, gravity field...
And if we don't suppose it is a scam, we can also say that a conventional energy source is obviously missing.
Now a possible lenr is not to be discarded. Lenr have been demonstrated in electrical arcs. A β- radioactivity due to the spark could be the source of energy. It would explain the need of an earth connection. A beta reaction frees electrons while creating ions. The earth connection permits to maintain the immediate neutrality of one of the two connectors of the spark gap. It provides instantly electrons, reversing the ions to the state of simple atoms as soon as a β- electron is extracted, and forcing the liberated electrons to flow in the circuit before returning to the earth.
My opinion.
A guy who uses a steak knife as a wire cutter would have no idea what your talking about. So how would he have stumbled upon that?
If you believe SR then take his advise:
Throw your cleverness  (oops, sorry, education) far away and just think about the process: what motivates the generation of electricity.
Respectfully,
Core
