0 Members and 104 Guests are viewing this topic.
core
Here are my thoughts, some of them have to do with my other experiments. I figured I would share them here.
That SR document has been around for awhile. Back on page 230 or so on this thread I spoke about the two transformer experiment that I conducted. But of course it was dismissed because smart people stated 'it's not OU!' NOTHING in that experiment was about OU. It was making a point that 'injecting a HV arc in a low voltage signal made the light flash brighter' That's it No more No less. What should be taken away from that is 'mixing voltages' may be important.
Looking at the Tariel video 'with the green box' there are a couple things about his sparkgap.
(A) Shielded wire is used to transmit the energy. The energy is so fragile and small he is afraid to lose it?
(B) NO WAY is that a spark directly from a transformer. Cosmo, by his own admission, does not release information about the High Voltage side.
Reflecting on point (B).
The 'Green box' video appears to be Tariel's first device. The SparkGap is so small that it lead me to believe that it is not coming directly from the HV transformer BUT is the 'product' of the HV side of the system. For the last 60 years everyone has played with SparkGaps from HV transformers only to get no closer to OU then when they started. So try something differant 'think outside the box' as they say.
NO WAY IS TARIEL'S SPARK DIRECTLY FROM A TRANSFORMER.
To quote SR from the document.
2) electric arc discharge is more accurate. Many simply to fanaticism collect classic transformers arc gap looking at them, the principle of operation of the plant Tariel Kapanadze - is also misleading and even what! Yes, the arc is important to install, but it plays a very different role, he is not involved in switching. Those who have collected these transformers, probably burned a lot of devices, must understand that they have collected is not something that Kapanadze, in other words - it is just RF transformer with a high yield, this transformer is only good for toys.
From that statement you can see some 'Key' words.
Keywordelectric arc discharge is more accurate:
Keywordsclassic transformers arc gap looking at them:
Explanation: He is talking about TWO types of discharges 'Electric arc' and 'Transformer arc' then he goes on to ridicule people who sit there and are fascinated about sparks. So it is 'safe' to say that the traditional way of getting 'Sparks' is not correct. There is another way to get 'Sparks' and Ferrite appears to make it easy.
http://www.youtube.com/user/core315185#p/a/u/0/TN4aVCYiHx4
Keywords (the arc is important) - (but it plays a very different role),- (not involved in switching)
Explanation: Everyone does the same thing with an arc (Tesla Coil) it is not being used that way. It is also not being 'switched' so this must imply it is constantly on and most likely being 'injected' somewhere. My first guess is that it has a lot to do with the Two Transformer experiment.
Keyphases:
(A) - I want to say that for the formation of sinusoids used power bipolar transistors, PNP and NPN conductivity, each in its half-wave, and how it works with the transformer is not going to say.
(B) -  ......but there are conditions under which the field can not do work, then take some action so that it can do the work.
(C) - I would say that 80% of the principle of the installation can be seen in a video installation of 100kW
  My understanding of electronics is limited but this is what I get from the above.
(A) The transistors are being used to create a Sinusoidal wave so it stands to reason that there are at least (four) independent coils on the mixing transformer. As an example we have the Degrees (0 - 90) - (90 - 180) - (180 - 270) - (270 - 360). Each independent coil is responsible for recreating a section of the 'Sine wave' (Kinda like using PhotoShop to create a picture using Layers).
  To take it one step further. let's say that one transistor creates the (0 - 90) degree part of a sine wave, nanoseconds later the other transistor creates the (90 - 180) part. Nanoseconds after that the first transistor creates the (180 - 270) part and then finally the (270 - 360) part. Now if I mix the 'Spark' of an electric field with Low voltage High Amperage (Like  SR's two transformer test) use that energy and build a sine wave as stated above wouldn't I be creating a 'Standing wave' in the coil? -- Just brainstorming.
Key phrase (B) above fall's in line with the Transistor switching. You also go back to the 'Dead Field'. Interesting note and Electric field and Magnetic field are two side's of the same thing. The energy of one creates the other.
[EDIT] - just want to state that a refrigerant, at the saturation point, is at a state that if energy is injected it becomes a Vapor, if energy is removed it become a Liquid. At saturation it is a combination of both. This is the most important aspect in refrigeration. Without it you get nothing.
My simple mind tells me this:
Dead field = 'Electric field'
1. So the entire mixing transformer is covered by an 'Electric field' maybe one side (+) positive one side (-) as in my other thread.
2. My mixing coil has (4) independent coil's
3. These coil's are in the 'Electric field' each coil is triggered to create a section of a sine wave. Each coil see's an in-rush of high current mixed with energy (voltage) from the 'spark gap'. The energy of the 'electric field' over that particular coil that is energized is passed to the magnetic field. When 'de-energized' the collapsing magnetic field augments the 'electric field'. This cycle repeats. Note: killing the high voltage would 'shut down' the unit as this would destroy the electric field and the 'boost' from the spark-gap.
Keyphrase (C)
If 80% can be seen then it stands to reason that 80% of the device goes into creating an electric field. On the video we have voltage but little to no amperage being used?
[Edit] - Injecting a steady DC voltage would enhance the electric field and possibly create the ' Magnetic amplifier' trick?
One more thing:
@LtBolo
Here is the quote from SR:
Suppose there is some stuff that is burning, but quickly recovered and again begins to burn, thus creating heat.
LtBolo you stated that a screwdriver 'heated up' in your core. What if you had (4) independent coils. Each one brought just the section it was covering to saturation (just like you are doing now) Wouldn't it stand to reason that if they where triggered at different times they would 'Heat' up and quickly recover? Kinda like SR said.
Also Cosmo stated about 40 or so pages back the following:
________________________
High voltage = Injector
Low voltage = piston
Ferrite = combustion engine.
Also on the above point:
If LtBolo's ferrite is getting so hot that it heats up a screwdriver wouldn't it stand to reason that energy is being transferred, via conduction, across the steel of the screwdriver?
If a thick ground wire is placed in the ferrite, and based on the above, wouldn't movement via conduction be created in the ground wire? What effect this has I have no idea. Maybe if the movement follows the creation of the sinusoidal wave, as mentioned above, then maybe a 'Standing Wave' is created in the ground wire???
Just my thoughts... maybe I'm just talking out my a$$.  ::)
Someone will quote me on that last line.
Respectfully,
Core
Trastos
Relevant Patents and documents of Kapanadze Patent WO2008103129A1 page 9
Converter wherein a piezoelectric transformer input signal is frequency modulated by a pulse width modulated signal
EP 0758159, US Patent: US 5739622 published on 14-Apr-1998
http://ip.com/patent/US5739622
Operation of a prototype Microgrid system based on micro-sources equipped with fast-acting power electronics interfaces
http://users.ntua.gr/stpapath/Paper_2.43.pdf
High voltage battery charger
US 2003/0038612 A1 published on 27-Feb-2003
http://ip.com/patapp/US20030038612
LtBolo
Quote from: core on October 19, 2010, 11:47:41 AM
Screwdriver got hot faster than ferrite got hot. It was definitely an induction effect. The problem was that I couldn't find any order to it, it just seemed like a super high eddy current at very high frequency...wavelength so short that it wasn't possible to do anything useful with it.
Shokac
hmmm. look this shematic.
Only need HV and spark.
And very important thing:
The most obvious approach would be to make a DC to AC inverter, having 110 or 220V AC output at 50 or 60 Hz, but this requires a rather large and heavy transformer. So it's better to use a high frequency, at least 25kHz, so a very small and cheap transformer can be used. See what it says in the picture regarding grounding.
This confirms Cosmos claim. Transistors do not serve in order to get 50Hz but that could get a smaller ratio of the transformer.
core
Quote from: Shokac on October 19, 2010, 02:15:51 PM
You may want to re-size that before Pirate see's it :D
Respectfully,
Core
