0 Members and 123 Guests are viewing this topic.
Trastos
This may explain why the patent refers to several documents that use DC circuits, both in LV and HV.  ;)
poynt99
I have annotated the patent drawings with the block nomenclature.
In the last wo2008103130_c.jpg, I have corrected what appears to be a significant error, in that the positions of the capacitor (5) was interchanged with the main board (HF Generator) (4). This correction not only makes the drawing in line with that of the older patent 129, but it now corresponds with the 130 patent text, specifically:
Opening the power switch (3), the user gives the electric energy received from the initial energy (1) to the first second part. being loaded with the electric energy received from the energy supply (1) the capacitor (5) serves as a pump, and provides the main board (4) to give electric to the system.
Main Board (4) transfers the high amount of frequency it generated to the first filter (6). First filter (6) stabilizes the frequency received from the main board (4) and regularly transfers to the first bobbin (7).
I've also taken the liberty to clean up and simplify the drawings.
More to follow.
.99
scratchrobot
@Core, Thanks for sharing your thoughts, very interesting. Can you tel me what do i need to perform that test you show in your video? Maybe you can show how you connect everything and what parts are you using? I have a poor electronics knowledge compare to you but I want to learn and experiment.
ps, never mind I read discription of your first video and now i understand your setup, what are you using for HV source?
Shokac
@poynt99
Miss you 2 and 2a. AC power.
Kapanadze say:
Opening the power switch (3), the user gives the electric energy received from the initial energy (1, 2 and 2A)
AC power is connect to load 220V 50Hz. This staff probably make 50Hz in the circuit.
All Others give current? Or.....
dllabarre
Quote from: LtBolo on October 19, 2010, 01:48:44 PM
Screwdriver got hot faster than ferrite got hot. It was definitely an induction effect. The problem was that I couldn't find any order to it, it just seemed like a super high eddy current at very high frequency...wavelength so short that it wasn't possible to do anything useful with it.
I had a soft iron rod in the middle of my coil and it never got hot.  It just got magnetized.
DonL
