0 Members and 116 Guests are viewing this topic.
sigma16
Quote from: cosmoLV on October 07, 2010, 02:11:10 PM
try to modulate your coil with some frequencies
see what happen with applyed HV and without HV
place near coil magnet to hear a difference
just take my first experiment setup diagramm, and where are AD or DC coil apply there some frequency, like 100 hz - 21khz and above
do it with HV and Without HV and if you placed a magnet you will hear the effect
, i'm not believe that it has no effects - i just know it 100% because i doo experiments  24 hours a day at 7 days at week, and so on...
I did a test similar to this with 4kv dc pulses (few ns wide) to a large coil with air core.  I held the magnet in my fingers and brought it near the coil and I could feel strong surging in the magnet, like the magnetic field was being made to surge and move.
sigma16
Quote from: LtBolo on October 20, 2010, 12:56:34 PM
The ferrite core device isn't Kapanadze's, it is SR's. I think that most folks here are aware of that.
Did SR ever take measurements?
Was his core magnetized or his pulses biased?
LtBolo
SR's device was a supposedly a self runner. I have no knowledge of how it worked, other than what Cosmo has suggested.
Cosmo...I actually understand Tiger's device for the first time, although I had seen it long ago. I'm guessing the key is that electric field can flip the domains more economically than a magnetic field...that is the key to making parameter change work above unity, yes?
Upon further study it does appear that Tiger's device is a resonant output. Initial pulses at the primary, yield a self resonance between the output and the flyback. Big problem with this design is controlling power on the load. The power has to build resonantly to get to usable levels, so the load needs to be non-linear...like a light bulb. The problem is that if you don't load it down enough, it runs away until it arcs. If you load it too lightly, it won't ever power up. To make power resonantly on the output, you would need a micro-controller and a very elaborate control loop to keep it stable.
I can see other possibilities that wouldn't require a resonant output, that should be far easier to control. Off to the lab...
gyulasun
Quote from: desa on October 20, 2010, 02:50:31 PM
Please don’t stomp on me here I am trying to make sense of it as everyone. For what is worth I think copper is here to slow decay of the inductance in ferrite. Sharpe rise HV (domain  all lined up) followed by slowing decay (domains decaying and reorienting gradually)  . The next signal resonates against residual creating additional resonance and inductance in center coil as per “Core” sine wave explanation. Ring it twice,  Edward Leedskalnin.
David.
David,
Sorry that you misunderstood, I wanted to notice copper foil does not neccessarily goes together with eddy currents,  foils can have thin enough insulated layers that help avoid eddies.  My intention was helpful, that is what I meant.
rgds,  Gyula
desa
Quote from: gyulasun on October 20, 2010, 04:01:29 PM
David,
I understand completely. Your explanation is appreciated.
David.
rgds,  Gyula
