0 Members and 116 Guests are viewing this topic.
core
Here is an excellent picture of Tariel's green box 'spark'. Note the coax cable being used. The shield wire is cut back and most likely connected to ground. If he didn't use coax I bet he would lose that fragile spark. Regular wire acts like an antenna and it would radiate the power. Tesla spoke about preventing power from leaving his systems.
Respectfully,
Core
Magluvin
hey Core
I like your thoughts of different kinds of wire. I never thought of it much.   And the idea of a glass covered ferrite intrigues me. I had often wondered if the ferrite had added capacitance to the coil, and probably does.
The pic above, it looks to me that maybe the wire is spark plug wire. Maybe. If it were shielded, the shield looks carelessly close to things that are hot, Leakage?   Also consider the wire soldered at the terminal, seems quite thick to be any coax I have encountered.  Just thoughts.  I have seen some high end ignition wires and the conductor  could be that large as we see here, and the wire is in a coil or tight spring like fashion.
But you could be right also.
Good stuff on the electric fields and mag fields. ;]   thanks for the info.
Mags
Pirate88179
I agree that does look a lot like spark plug wire to me also.  About the spark gap, that thing on the left, the first time I ever saw it and even tonight, it looks like an allen wrench.  Again, no problem there as he was just using things he had available to him.  Does anyone else see this though?  I noticed this in the first videos I posted and now, I still see it.
DimaWari
@core
This is off topic. I guess were heading towards the effect of NEGATIVE IONS....
Thanks core for the information... You really understand it..
baroutologos
baroutologos,
I conducted the experiment to SR's explanation. My findings where by observation only. Hopefully in the coming days I will conduct the experiment again this time I will video tape it and upload it to YouTube.
Respectfully,
Core
Thanks Core,
by experimenting seeing each-other's setup and discussing we might have a chance going somewhere instead of talking endlessly.
