0 Members and 116 Guests are viewing this topic.
zen_guru
hi guys.
you're all on a wrong way. this device is not about magnetic and electric fields. kapanadze coil has no iron or ferrite core. all this is much more easier: frequencies. you can light a bulb and a neon tube just using freq. if i'm wrong, i want to see kapanadze, sr, tiger, madsatbg using that output power to run a motor. they are not doing that because a motor needs a certain freq (50hz), and their output is about 20-30khz.
i saw some replica devices on the internet, but i didn't saw cosmos's. i think cosmos is around just keeping us to see that this s*** is much more easier to build. you all have a solid knowledge and you're going in too deep.
baroutologos
@ Above,
frequency my friend does not operate motors. Motors are operated by voltage and amperage working on a particular frequency. In other words operate by energy (as oil) and frequency is the type of electric energy as diesel.
I repeat without enstablishing facts in the workbench, all we have here is talking and talking and talking. I personally always share my failures as well as my few successes and i am more than willing to discuss and criticise them.
A piece of advice
SInce its the nature of this forum, any fellow experimenter that observes a fact "e.g. i did that and it made that" style, it would be most appropriate to present setup, specifics and observed behaviour with some schematics, photos or videos for others to see, inspired, motivated to employ an idea or disillusion an wrong idea.
zen_guru
Quote from: baroutologos on October 21, 2010, 03:56:53 AM
@ Above,
and what does frequency (low voltage and low amperage) operates? bulbs and neon tubes. that's why all the devices we see on the internet can light only bulbs and neon tubes.
let's say sr has an output of 220V 50Hz 200W. i want to see him powering a 150W motor.
what are we looking for for the output? more voltage and amperage or more frequency? until now i think we have more frequency.
ps: you'll se my experiment results soon.
bolt
If it lights bulbs it will run a motor. If the o/p is not 50/60hz and some higher frequency its no big deal just add a diode bridge to make DC then run a universal brush motor like a drill, vacuum cleaner or mixer. Lights are used mainly for a visual experience so you can see the power. Not so effective running a toaster:)
forest
bolt
Nobody answered my question about Kapanadze green box and clampmeter. I saw a response from Steven Mark that you cannot fool clampmeter,so there is 23A going on in ground wire in kapanadze green box as measured in video even if frequency could be higher or lower then 50hZ. Can you confirm ?
