0 Members and 353 Guests are viewing this topic.
bolt
Quote from: forest on October 21, 2010, 05:50:42 AM
bolt
Nobody answered my question about Kapanadze green box and clampmeter. I saw a response from Steven Mark that you cannot fool clampmeter,so there is 23A going on in ground wire in kapanadze green box as measured in video even if frequency could be higher or lower then 50hZ. Can you confirm ?
Its a ground based system using the ground as potential difference therefore and i assume there is 23 amps on the ground wire which it explains why in some of his vids its starts smoking on poor earth contact.
Regarding the frequency its possible to create 50/60hz direct out of the large coils using magnetic modulation. This is done using the 2 power transistors in push pull to create 50hz sine to provide the o/p modulation without using an inverter.  This is pretty much fact the o/p is 50hz because kapanadze did another vid some where and ran a 50hz 10HP induction 3 phase motor in a workshop.
This differs to the TPU which is mostly DC with 5Khz sat on top.
sigma16
Quote from: bolt on October 21, 2010, 04:16:23 PM
50Hz was not the output of the second coil.   In the patent he shows a device after the coil to create the frequency.  Perhaps this was an inverter.
baroutologos
Quote...
i want mentoin that: "before talk such things - do some experiments" i tell why i`m not showing video`s already...
your choice is believe or not believe, i talk what i see and about facts, if you have already build device and have facts, then go and stop Trolling ;)
Hillarious reply. What experiments exactly Cosmo are you talking about?
All i see from you is hints and tips about what? And an experimental setup that does not seem to work as claimed
cosmoLV
Quote from: sigma16 on October 21, 2010, 04:53:02 PM
No!
50Hz are the output frequency! and this is the fact. . . .
Keep your chakras opened :)
sigma16
Quote from: cosmoLV on October 21, 2010, 05:24:34 PM
No!
What is the source of this "fact"?  I can find no reference of Tariel Kapanadze stating that the output is 50Hz.
I have translation where Tariel says he powers the device from a battery through an inverter.  When he connects output back to input he uses a device in a metal can between the output and the inverter.  If output is 50Hz, why he needs an inverter?
See attached, page 4:
