0 Members and 91 Guests are viewing this topic.
sigma16
SR193 used to be "admin" on next-energy.ru forum
In some of last posts, before he stopped posting, he answers a few questions:
(Answer 1228)
Quote: temptemp on March 31, 2010, 17:52:21
Пара вопросов изобреÑ,аÑ,елю. A couple of questions to the inventor.
1. 1. Какие парамеÑ,ры влияюÑ, на "выÑ...од" энергии? What parameters affect the "output" energy? Иными словами, как расчиÑ,ываеÑ,ся усÑ,ановка на нужные напряжения и Ñ,ок? In other words, as calculated by setting the desired voltage and current?
2. 2. Ð'ажен ли моменÑ,, коÑ,орый мы видели в ролике с зелÑ'ной коробкой, когда чÑ'рный провод проÑ...одиÑ, внуÑ,ри каÑ,ушки? Is it important moment that we saw in the video with a green box where the black wire goes inside the coil?
3. 3. 50Ð"ц используюÑ,ся для первичного создания Ñ,ока в цепи? 50Hz is used to create the primary current in the circuit?
ИзобреÑ,аÑ,ель Тариэл Капанадзе, его у нас неÑ, на Ñ,,оруме, к сожалению. Inventor Tariel Kapanadze, we do not have it on the forum, unfortunately.
1) МощносÑ,ÑŒ пропорциональна размеру Ñ,рансÑ,,ормаÑ,ора. 1) Power is proportional to the size of the transformer.
2) Не важен. 2) Not important. ОÑ,личный способ крепления провода. A great way to fixing the wires.
3) Не используеÑ,ся. 3) Not used.
I agree with some of these answers, but I do not think he has the real understanding.
sigma16
http://translate.googleusercontent.com/translate_c?hl=en&sl=ru&u=http://next-energy.ru/forum/index.php%3FPHPSESSID%3D7d8d8baf09ee8a055ffe92453a962ce5%26topic%3D40.msg2508&prev=/search%3Fq%3Dnext%2Benergy%2Bru%26hl%3Den%26prmd%3Dv&rurl=translate.google.com&twu=1&usg=ALkJrhjrg4odYGag7OoldskdlJ6RdmxZiA#msg2508
QuoteQuote: velikimedo on March 31, 2010, 17:43:46
Do Kapanadze coil use metal core ?  Probably metal tube, or metal wire inside coil ? I presume it is not magnetic , probably aluminum or brass, but not iron?
SR
Metal there is not used. Metal possesses inductance that raises losses on magnetisation.
PS:The circuit wrong. PS: The circuit wrong.
So, SR says no metal.
SR also states that resonance of a tuned circuit is not used, and no beat frequency.
He mentions nanoseconds several times.  Might refer to the pulses.
in answer 1159 he mentions a compound of the EM field
armagdn03
A question a bit of topic, maybe not....
A while back a few people were showing "tesla coil" style coil setups using only one transistor, and a gate resistor to run, does anybody have this very simple schematic that they would be willing to send my way?
I wish I could turn my brain off sometimes, then I could get some sleep.
bolt
Quote from: sigma16 on October 21, 2010, 04:53:02 PM
50Hz was not the output of the second coil.   In the patent he shows a device after the coil to create the frequency.  Perhaps this was an inverter.
Forget the patent that was a very early block schematic. In his translations and videos he clearly states 50Hz o/p and as i said he ran large induction motors from it. Also it would prove rather expensive to have an HF or DC o/p and then have to buy a 10kw inverter from ebay:)
poynt99
It appears most if not all of TK's devices are 50 Hz AC output.
They all "hum" when operating, and at least one unit (the 100kW device) has 3-phase outputs. This unit also appears to be 50 Hz AC input.
Someone tell me it's not as simple as a 50 Hz step-up transformer creating the spark across the gap (voltage ratio depends on size of unit) which then feeds the special output transformer primary, which then gets stepped back down to 220V on it's secondary  ???
.99
