baroutologos
...Engineers were enraged. Those who had missed his most early shift from alternations to impulses, failed to comprehend the vast distinction between "stationary waves" and " standing waves"...
One cup of theory to kick-start the day... Experiments, photos and guidelines for replications pls. No smart-empty words.
forest
so many tips from the past...  ;D
recreating lightning
splitting the positive
ring twice
don't kill the dipole
what else ? please ? what tip is using Kapanadze ?  :P
gyulasun
Hi Penno,
Try to move your setup further away from the lab supply by using say 3m supply wires and see if the effect stays or not. I suspect the high voltage EM field from the spark fools the inside control electronics of the lab supply.
Maybe use a bigger metal sheet as a screen if you have no big room for moving the setup away from the lab supply (or moving vice versa).
Another test would be to use a low pass filter in the supply wire which is a series choke coil of some milliHenry value (DC resistance of a few Ohms) and parallel electrolytic capacitors on both sides of this choke. But I suspect the main problem is the spark's effect getting into the control circuits by radiation (i.e. EM field).
Gyula
Quote from: penno64 on October 23, 2010, 03:41:05 AM
Hi guys,
I am looking for some advice/understanding.
I built the STINGO circuit from over at EF.
When I power a car coil and create wonderful arc/sparks, even
though my LAB power supply is set to 6v and current limit to around
300mA, as soon as the sparks begin, my power supply meters show up to 10v and nearly 1A.
I tried using a diode inline with the positive. No change, same thing happens.
I would really appreciate if someone could at least give me an idea why this is happening.
My thoughts are that HV spikes are getting back to the PSU - but I don't know.
Kindest Regards, Penno
exnihiloest
Quote from: sigma16 on October 22, 2010, 04:32:49 PM
There are many kinds of "resonance".
You should start with just the one coil, excite it different ways and probe around it with various ways to detecting energy.
With such precise methods as exciting in different ways and probing around, sure I will find out Kapanadze's secrets. Just a question of time for testing the 1010 possible combinations.
Thanks, you put me in the right way! I confess that I had the bad idea to try only the a priori most relevant options.
:D
penno64
Hi Gyula,
Thanks for the advice.
Are the caps either side of the choke on the positive and across to negative ?
Like this
                                                   Choke
Positive ------------------+------\\/\/\\/\/\/\--------+--------
Negative -----------------+-------------------------+--------
I'll try that.
Regards, Penno
