exnihiloest
Quote from: penno64 on October 23, 2010, 03:41:05 AM
Hi guys,
I am looking for some advice/understanding.
I built the STINGO circuit from over at EF.
When I power a car coil and create wonderful arc/sparks, even
though my LAB power supply is set to 6v and current limit to around
300mA, as soon as the sparks begin, my power supply meters show up to 10v and nearly 1A.
I tried using a diode inline with the positive. No change, same thing happens.
I would really appreciate if someone could at least give me an idea why this is happening.
My thoughts are that HV spikes are getting back to the PSU - but I don't know.
Kindest Regards, Penno
Spikes create HF that can disrupt measurement devices.
Few watts from my short wave transmitter connected to an external antenna make the display of my nearby power supply completely crazy.
nievesoliveras
penno64
Jesus,
Very rough circuit -
TIP30 should be TIP32C
Battery is really LAB PSU
Loose lines from coil = spark gap
Regards, Penno
gyulasun
Hi Penno,
Yes, that is how I meant.  You can use ferrit rings, taken from PC power supplies and wound fully up with 0.3-0.4mm enameled Copper wire.
Unfortunately, the EM field itself the spark creates can fool the inner circuits of the lab supply, in this case the above filter has little or no effect. This is why I suggested the distance test with the longer supply cable and the above low pass filter should be placed right at the output of the lab supply, (the longer cable will pick up much more EM induction from the spark),  a temporary test to learn which way the interference enters the lab supply.
  Gyula
Quote from: penno64 on October 23, 2010, 05:19:58 AM
Hi Gyula,
Thanks for the advice.
Are the caps either side of the choke on the positive and across to negative ?
Like this
                                                   Choke
Positive ------------------+------\\/\/\\/\/\/\--------+--------
Negative -----------------+-------------------------+--------
I'll try that.
Regards, Penno
nievesoliveras
