0 Members and 356 Guests are viewing this topic.
energia9
hello all, it is sad to see that only some of you do the experiments while everyone has the ability to make the device working, many of you just sit front of the computer and try to solve the problem, this is not an offense to anyone, but a call to everyone, please stand up, all of you should make the experiments continously, the mystery will not be solved by guessing or theorizing, i have seen many threat and bad language to others , im asking, is this the way you going to solve anything? do you wonder why others dont submit the working device to you?  just observe yourself from a 360 angle, things are nowhere the way it should be, you will possibly ask where am i coming from,
im coming from the truth, im not inspecting anyone, im trying to help, listen !if you just wait while somebody someday will submit anything you are wrong, you can wait till you get bored and run off..  listen very carefully before you start to criticise anyone or anything.  there are 100 s of ways to approach the "so called mysterious kapanadze machine"
if you are patient enough,  you will check this picture
http://3.bp.blogspot.com/_hGQr6DGstUQ/TKOhgsankxI/AAAAAAAAArg/Vq3lgBXxMxA/s1600/transf+eff.png
This is just one part of the working operation  where the capacitor is the pump which feds back the energy,  this can only be done at the right frequency at the right timing with the right amount of dc low voltage electricity to make your coils inductance greater, it is like a combustion engines spark timing,
"it is not as simple as a capacitor though, the reason why you cant do the trick is because you dont master it on your own, you are trying to listen to other people....
poynt99
Greetings energia9.
Are you associated with the Kapanadze group and hence speaking with some knowledge of the device, or is this information coming from your own experiments?
.99
sigma16
Quote from: energia9 on October 26, 2010, 07:27:38 AM
Energia9:  is your username a reference to Energia Celeste?
You say that the working device will not come from guessing or thinking, then you show an incomplete diagram.  How is this supposed to help?
energia9
No
The answer will come from The correct Logic thinking, this is not an incomplete diagram, it is a logic pattern, it seems that you think i have a working device, i have no working device my friend, im sorry, this picture is an indication to show you that you must accomplish an energy gain, which is greater than COP 1,  it has to be at least the amount which stays above the COP1 level with losses inside the system,
in my earlier experiments i have seen that magnetizing a hf hv transformer brings down input current and doubles spark on the output, this is still not above COP 1 only more efficient,   earlier i did a very very simple experiment, i have got "lost of the effect"  i would like to show you this simple picture i have made back around a month ago, please find the attachement,   note that the effect only worked with correct frequency adjustment and when i disconnected the power source the lamp were still lit with the same brightness, the frequency did somehow stabilized by the procedure i followed:  connected freq gen to the transformer  connected the transformer to the coil, adjusted coil, after disconnected from coil, then disconnected from transformer, lamp still worked from distance, while the freq gen leads were in my hand and away from the coils, the effect i observed occured only once, because i didnt know what happened, i moved the coils and i could not observe the same thing. this well could be that i dont get something, but if you can tell me why this happened....
here is the picture:
http://4.bp.blogspot.com/_hGQr6DGstUQ/TMbyHFRvj6I/AAAAAAAAAr4/c9wrlz3NTRU/s1600/sumermagor%5B1%5D..png
sigma16
Quote from: energia9 on October 26, 2010, 11:19:21 AM
No
Each person has their own ideas and to say that the Kapanadze devices work one way or another is premature unless you have proven your idea.
Very little details area actually shown of the coils and nothing is shown of the pulse system except the spark gap.  Everything you cannot see is just a guess based on what you know.
The Kapanadze coil demonstrated in the garden is the only one that is shown clearly to get an idea of how it may be wound.  Not clearly enough for exact determination but only for a good guess.  The out coil on this device is wound of a large conductor and appears to be copper tubing.  This coil appear to only be connected on one end to the load and the other end is left free.  If a wire were fed back through this tubing, the connection is not shown, so we can only guess.  This device also shows the thick conductor through the center of the large coil.  This thick conductor is connected to ground and appear to be connected to other end of load.
What effect do you know of that will induce conduction current into this circuit?
Your diagram shows something different.  You have no conductor through the center of the coil, your output coil is the larger coil and this coil is grounded.  You use an iron rod or ferrite core.  I have found no verifiable reference that Kapanadze used a ferrous core, and I doubt that he did.
You mention that the light stayed lit when you disconnect the leads to the primary coil and the light stays lit, but the light goes off when sig gen is turned off.  This sounds like the sig gen is powering the lamp.
When you diconnect the leads from the sig gen to the transformer and the light is lit, is the sig gen still on?
If the "Kapnadze Riddle" will be solved it will be by luck, good guess, and good experiment.
