0 Members and 363 Guests are viewing this topic.
forest
energia9
What generator output ? Squarewave ?
Bulb, capacitor parameters ? Any details ?
energia9
In the picture i shown the signal generator was still on when the lamp were lit yes, but i could not replicate my own experiment since, this is what im asking, what happened?  the two leads of the signal gen was in my hand and the lamp still burning, in other experiments no such phenomena was found, i disconnected the source and the lamp went off in other experiments,
this is what bothers me, that there was a "phantom connection between the signal gen leads and the coil in distance,   if this was transmission of electrical energy through one lead then that is extremely efficient i must say.. and i have not seen anybody doing this.  even my self i could only make it once, and this did happen but i dont know what kind of stability have i accomplished,   ferrite in Kapanadzes generator- i can not say anything either, when i did the above experiment i had no iron in the core and as i said iron dimmed the light in the experiment,  or if i did put ferrite toroid inside i had to readjust the frequency to lit it brighter because it has changed, just relook what may have happened,
energia9
Quote from: forest on October 26, 2010, 01:41:57 PM
energia9
1.2 megahertz square wave were the best results 0.4 v at 5 ma according to my meter,  bulb 1 watt, capacitor 450 volt  420 microfarad
But In the experiment where i disconnected everything i could no way measure any kind of power input as it was disconnected
forest
Quote from: sigma16 on October 26, 2010, 01:34:39 PM
Each person has their own ideas and to say that the Kapanadze devices work one way or another is premature unless you have proven your idea.
Very little details area actually shown of the coils and nothing is shown of the pulse system except the spark gap.  Everything you cannot see is just a guess based on what you know.
The Kapanadze coil demonstrated in the garden is the only one that is shown clearly to get an idea of how it may be wound.  Not clearly enough for exact determination but only for a good guess.  The out coil on this device is wound of a large conductor and appears to be copper tubing.  This coil appear to only be connected on one end to the load and the other end is left free.  If a wire were fed back through this tubing, the connection is not shown, so we can only guess.  This device also shows the thick conductor through the center of the large coil.  This thick conductor is connected to ground and appear to be connected to other end of load.
What effect do you know of that will induce conduction current into this circuit?
Your diagram shows something different.  You have no conductor through the center of the coil, your output coil is the larger coil and this coil is grounded.  You use an iron rod or ferrite core.  I have found no verifiable reference that Kapanadze used a ferrous core, and I doubt that he did.
You mention that the light stayed lit when you disconnect the leads to the primary coil and the light stays lit, but the light goes off when sig gen is turned off.  This sounds like the sig gen is powering the lamp.
When you diconnect the leads from the sig gen to the transformer and the light is lit, is the sig gen still on?
If the "Kapnadze Riddle" will be solved it will be by luck, good guess, and good experiment.
Huh !? By what  ???
Maybe by that http://www.tfcbooks.com/patents/0593138.htm ?
sigma16
Quote from: forest on October 26, 2010, 01:53:34 PM
Huh !? By what  ???
I think the two are distantly related in that they use the influence the aether medium.  The purpose results are very different.
It might behoove some of you experimenters to know that a Tesla Magnifier does not have to be driven by a Tesla Coil (transmitter) and can be driven by an ordinary transformer.  This directly out of Tesla's Colorado Springs Notes.
