0 Members and 39 Guests are viewing this topic.
energia9
Coruscant
Hi folks,
Its been a bit.  I've not read thru the last 100 or so pages but was curious about the status of the kapanadze replica attempts.
I've been off on a sidebar sorta exploring darsonval type setup thats been somewhat adjusted to what I've been playing with.   Its a 3 coil setup.   It uses a primary laid out darsonval style, a secondary setup Tesla style and a Tertiary that is placed directly over the primary and is slightly smaller in diameter but the same in turns count as the primary.
The Tertiary appears to couple magnetically to the secondary and perhaps primary to some degree and it oscillates at high frequency with a few thousand volts on it which let me charge up some relatively small capacitances which discharge thru a spark gap once a threshold is reached (as determined by the tertiaries spark gap).   If I make the gap so big no arc discharges, I see a max voltage accumulate of ~7kv dc.
What is curious is that the input to this setup is 120vac at 60hz with a current of 600-650mA, for about 60-70watts input.   Its this amount input regardless of if the tertiary is collecting or Not collecting.   The tertiary could be removed and the devices primary still runs on this input power.
However with the tertiary wired to collect off one end the input still doesn't go up.   The amount collected and the breakover voltage is determined by the combination of the spark gap and the collector capacitance that was selected.   75nF as collector lets me adjust the spark gap for discharges at about 3hz at 1kvdc to much slower say .1 hz (or 1 pulse every 3-5seconds) at 4-5kvdc.   While using some ~230pF has a near constant reading of 3kv in what looks like a constant arc to my eyes.  (I haven't scoped it to find out what freq its running at as I have already burned out 3 scopes and have no funds to buy a 5th.)
A vid of this setup (shown with the 1uF cap that I've since removed as it wasn't doing anything upon further experimentation) is here on youtube.
http://www.youtube.com/user/bellerian1?feature=mhum#p/u/0/lLqXmsVi-dM
Its not Kapanadze per say, but it is an offshoot that might provide some other ideas to you folks here on this forum.
Regards,
Gene
dllabarre
Quote from: Coruscant on October 26, 2010, 04:17:37 PM
Hi folks,
Regards,
Gene
Youtube says "channel not available" for the above link.
Coruscant
Quote from: dllabarre on October 27, 2010, 08:55:11 AM
Try this URL:   http://www.youtube.com/watch?v=XKoCcou_hvQ
You can get at my channel here:  http://www.youtube.com/user/bellerian1
If it still doesn't work for you, try a different web browser as thats been noted as an issue in the past, maybe mozilla or opera or chrome.
Regards,
Gene
