0 Members and 44 Guests are viewing this topic.
catalyst
@core:
Call me an idiot if i'm wrong. Permanent magnet DOES NOT create transverse wave flux! It's longitudinal wave flux. Same as gravity is longitudinal.
Example when Frolov made this experiment (it's easy, even baby can do it, yet he did the experiment (none of us doing real testing!!!!) he see the effect. http://www.thelivingmoon.com/41pegasus/01archives/Electrogravitics.htm
It's about longitudinal dielectric filed and gravity field (which is the same flux field) canceling or adding together. Levitation is done this way.
Scientific community do it look so difficult. Forget old knowledge. Just go with Nassim Haramein, he brings it to the point. Haramein embarassed them so many times while they look like idiots while everything is so simple. Watch his videos with full heart to not miss any part.
So if you go with coils, using high amperes, you only waste energy in my opinion.We must go with capacitors, they do not need any ampere. That's why Tiger2007 use somehow plates to involve this field flux.
I was thinking a lot a few days back. And now you mentioned something similar. That's why i did write this reply. But instead going the wrong flux way, use the right longitudinal flux to imitate a permanent magnet movement inside a coil.
Why do you think that since your ampere-meter moves if you move a fix magnet in a coil, that transverse flux is the main cause from magnet ? Maybe it's longitudinal flux from magnet that goes TOGETHER and forces that transverse flux also to show up which in turn creates amperes ? And if we connect one end of coil to ground like TC did, we can have any large amount of amperage depending of our magnet movement imitation and it's flux change rate. Independently of our control circuit, which would eat very little energy.
Maybe Tariel do it the right way with voltage and he need no ferrite. Maybe SR and Cosmo used the ampere way, the unfavorable way with not much yield.
If i could do experiment, i will do integrate plates and try to flip flop voltage on capacitor. I would perhaps have 2 of such capacitors, one from middle to left and one from middle to right on the coil , to create a flip-flop flux, center GND. Same, using 2 transistors, when one is shut (OFF) other is active (ON). I would discharge the OFF cap when other is applied with high voltage and vice versa. Or the discharging itself and timing thereof could be managed with spark gaps.
@stivep:
All my problems come from 5-year old IQ in every person i met so far. Everybody go with the guy saying "i love you" by opening her legs, the low level love, and waste herself forever. They think this is love! LOL. I can not find a lady who also will open heart level love (open your arms and hug) or even the head level love (open your consciousness and understand reality and me and support me/us to 100 %). There are no lady with heart and head level love, only low life form wh*res. That's why the world population must go down, it's full with this and their counterpart man. Please nature, mother earth, take them down (or even the bad guys in power (with chemtrails, vaccines, viruses etc trying reducing population), Upps (did i speak wrong now ?!?!) :-) )!
This subject is related with free energy.
catalyst
Additional thoughts:
(a) Coil + ferrite
(b) Coil + magnet
(a) is different than (b).
(a) uses transverse flux to transform energy from one side of transformer to other
(b) creates current !
In category (a) we have simple transformers, the BIFF transformer, SR device etc. Yes we even hack the ferrite (finding right HF to make it resonate to get more flux lines).
In last post of me and in Core's we go to the idea to create a MAGNET and eliminate the mechanical movement by electrical means. And the idea is simple. The old known simple coil + magnet movement. I tried to point out that magnets have longitudinal flux. Everybody seems to confuse transformer/ferrite flux with magnet's flux.
One more claim from me. A magnet is a temperature hack! You align particles that are responsive to dielectric flux while they are embedded in fluid medium. Then you cool medium down to solid form and they're trapped! Thus you have permanent dielectric flux. It's real power that can be harnessed. If you bring back to fluid and then solid again, it's magnetic will be lost i'm sure.
catalyst
Two practical tests that i will perform if i can:
1) Take a neodymium magnet, place 2 flat conductor plates on N and S. Do not touch magnet (place paper in between). Measure voltage. Is there voltage measurable ?
2) Take 2 neodymium magnets and a cylindrical coil. Place each magnet on one end of coil. Like: NS-coil-NS. Flip magnets quickly by hand to this: SN-coil-SN. Do we measure any current movement in coil ?
penno64
Guys,
On madsatbg youtube page, you will find in his favorites, in the second half of the video,
you are shown how to build the coil.
I have several questions -
1. Is the centre part metal or just a plastic core
2. Is this simply driven from a freq generator
3. Are the wires from the copper core simply soldered at the ends
4. and is it the same side or opposite of slit in copper.
I know our answer is in this video !
Regards, Penno
