0 Members and 148 Guests are viewing this topic.
catalyst
forest
hey
maybe it's that simple : shake collapsing magnetic field
I feel that when you ring a bell bell response, but when you ring twice ambient response.Just an idea....
Shokac
I tested the following setup and got a surprising result.
I made the scheme as proposed by Cosmo. I combined the ammeter to extract DC voltage that powers the circuit. When you hit the right frequency of LV and HV to get the electricity supply LV halving a light load 50% more. Spark gap is quiet and weak.
Embedded power on HV side is half the size of the one I took at the source of the LV.
Load glows stronger force before a combination of frequencies affected.
If the HV is connected via large coils (as in garden Kapanadze set), source current LV almost gone .?????
As someone has already said on the forum (think Cosmo): Unable to get out more than it invests, but the HV can get the source current vanishes
HV is used as a current source, but without the required input voltage can not even get to the exit.
energia9
This is from my previous experiment when i had the power supply disconnected and the bulb still glowed , after i tried different things, and one interresting thing was that i had twisted the cable on the output lamp, and there was a switch on and off, and even when i switched the lamp off, the cap discharged in some interresting pulsing way, i could feel the twisted wire gave off a ticking sound and i could feel it. this only happened in one stable frequency again, you can either explain it away or investigate it further, i have my logic pattern to follow i will follow it to the end and then publish the working device.
this is the simple experiment i did:
http://2.bp.blogspot.com/_hGQr6DGstUQ/TMlKAUWpJdI/AAAAAAAAAso/880f8yYJMiA/s1600/G.bmp
penno64
Hi Energia,
May I ask what voltage was the square wave pulse and what was the lamp volts/watts ?
Kind Regards, Penno
