0 Members and 145 Guests are viewing this topic.
energia9
Quote from: penno64 on October 28, 2010, 06:33:37 AM
Hi Energia,
May I ask what voltage was the square wave pulse and what was the lamp volts/watts ?
Kind Regards, Penno
square wave pulse 10 volt this time, 150 volts at secondary,  lamp is 25 watts, power in capacitor= far enough to kill a man, it loads to thousand times more than the input, that is when you wait about 5 seconds  to charge up then discharge it through the 25 watt lamp, and it will be lit once in a micro sec,
the lamp were off when the twisted wire did something which i cant explain.
zen_guru
@energia9:
do you have a ferrite core in that coil?
can you tell the setup of the coil? turns, gauge?
what is your bulb rated voltage? 110 or 220?
thanks!
energia9
Quote from: zen_guru on October 28, 2010, 07:01:51 AM
@energia9:
thanks!
Iron will dim the aparatus, the setup of the coil i allready posted see the above picture from my post, Bulb voltage 220-240 volts,   i have not counted turns and i have dissasembled the primary and secondary all i have in solid now is my ground coil with many turns, it is necessary in these experiments,   the gauge i cannot tell either, i have my wires dissasembled from a microwave oven transformer, and the prim and secondary are stranded mains wire,    one thing is very important in this setup that the Grounding coil has to have a very high inductance and resistance, by this you can place your primary and secondar coils as far away as you want it, even works better farer,  Without iron.
energia9
something about iron and ferrites,  they are not good in high frequencies, only if you have a higher permeability cores, otherwise they will dim the light of the bulb,  Do you think Nikola tesla Had high permeability cores?? (i donno)  you can possibly achieve nice effects with high permeability cores and ferrites, but i dont know, iron might not be needed for the tesla energy effect, dont take my word, do your own experiments, we might find that we dont need iron and we might find that we do, 50-50 if we dont know how it works.
Anyway read the eric dollard book, he done his experiments which are 100%real, its good that he dont just theorize, he have tried many things
tesla: Remember, now, that the water is incompressible, that the bag is perfectly elastic, that there are no hysteretic losses in the bag due to these expansions and contractions; and remember also, that there is a vacuum, in infinite space, so that the energy cannot be lost in waves of sound.  Then, if I put at a distant point another little pump, and tune it to the rhythmical pulses of the pump at the central plant, I will excite strong vibrations and will recover power from them, sufficient to operate a receiver.  But, if I have no pump there to receive these oscillations, if there is nowhere a place where this elastic energy is transferred into frictional energy (we always use in our devices frictional energy -- everything is lost through friction), then there is no loss, and if I have a plant of 1,000 horsepower and I operate it to full capacity, that plant does not take power, it runs idle, exactly as the plant at Niagara.  If I do not put any motors or any lamps on the circuit, the plant runs idle.  There is a 5,000 horsepower turbine going, but no power is supplied to the turbine except such power as is necessary to overcome the frictional losses.
