0 Members and 234 Guests are viewing this topic.
dllabarre
Quote from: core on October 29, 2010, 09:44:04 PM
I was hoping, and praying, to find a quote from Tesla saying the below. To me this is 'the most important' thing to do.
Tesla
Tesla did not allow the magnetic field to manifest itself. So at 90 Deg. the mechanical break was opened. Closed again at 270 Deg. The electric field was used to charge condensers and then a spark gap was used to inject the power.
What can be taken from the above quote. A 'break' of some kind must be used. This break has to be timed to prevent the magnetic field from being created. Spark gap is used to 'discharge' energy accumulated in the condenser from electric field.
Not doing the above is simply not Tesla.
Respectfully,
Core
Awesome find!!
Thank you
DonL
core
Tesla
Respectfully,
Core
The following link is the patent to the above device.
http://www.teslauniverse.com/nikola-tesla-patents-568,180-producing-high-frequency-currents
Respectfully,
Core
penno64
Hi,
Do you reckon Kooler has nailed it ?
Have a look in the SQM - VTA thread.
Penno
Pinoy_Tech
Quote from: Shokac on October 28, 2010, 04:24:56 AM
I tested the following setup and got a surprising result.
I made the scheme as proposed by Cosmo. I combined the ammeter to extract DC voltage that powers the circuit. When you hit the right frequency of LV and HV to get the electricity supply LV halving a light load 50% more. Spark gap is quiet and weak.
Embedded power on HV side is half the size of the one I took at the source of the LV.
Load glows stronger force before a combination of frequencies affected.
If the HV is connected via large coils (as in garden Kapanadze set), source current LV almost gone .?????
As someone has already said on the forum (think Cosmo): Unable to get out more than it invests, but the HV can get the source current vanishes
HV is used as a current source, but without the required input voltage can not even get to the exit.
Hi,
     I'm curious about your HV, are you using a push-pull driver ckt, totem pole or a single stage drive? May we have your schematic if okay with you? Or any link or any info as to whether what kind of contruction you have made on your hv? Is that DC or AC output? I'm designing a push-pull HV drive circuit, preferably a double contour as described by our fellow friend Cosmo. HOT tv flyback can also possible to modify, we can remove the trippler diode inside if we want, but there must be a special tool and chemical to use for soaking.
Thanks,
jronel
