0 Members and 124 Guests are viewing this topic.
energia9
Quote from: Pathfinder on October 30, 2010, 05:43:53 AM
Some more for Tesla
i have had experiments using this concept long ago, and actually when you connect the ground side to a metal plate lying on ground the bulb will shine twice as much as with ground. at specific frequencies the bulb lights up even more but also dependent on you iinductance of your coils, i found that i could raise inductance twice as large with a magnet stacked to this kind of transformer. the output was twice as much.  you reminded me of something about this too, so great thanks to you friend
cosmoLV
Some more for Tesla
This concept are "Totally wrong" represents a Don Smith device concept who are not and newer works!
internet are full of garbage of these concepts! Think for yourself and think who are placing free energy device on Network - you are right, no one!
Keep your chakras opened :)
energia9
Quote from: cosmoLV on October 30, 2010, 04:24:46 PM
I think the same, beacuse the apparatus is not as simple as this, but simple if you understand it, and those who understand it are not likely to post anything because they observe things from different angles.  i have actually gained rememberence from this picture that he posted but it is completely different,  but cosmolv we might talking about two or several more devices here which are related to eachother in some way but they work on totally different principles,     i think that by magnetizing a piece of iron and raising the inductance of a wire can let more electrons flow through it and this is a more efficient way to transmit current, if you have seen my picture of my logic pattern and my previous experiments then you know where im up to.
desa
My friends experimenters.
If you permit me I would like to introduce one of my experiments that is absolutely stunning. I mean it in most explicit term. This experiment is absolutely deadly so pay attention where your fingers are if you decide to replicate. I am at it for some time and need some assistance to get my reed switch replaced with the solid state ASP. The first time I started the apparatus I used regular reed switch and it lasted two firings. I got some more from EBay and it was destroyed in a pif. Finally I got some strong one that can handle 10.000V and with it worked perfectly .  The parts used are of the shelf nothing special. Coils are disassembled solenoid, magnets are from old microway Magnetron unit taken apart. The ferrite coils are power supply filters and Lincoln rods are from local welding supplier. Most fascinating thing is as you can see from the videos that as I pas the magnet over reed switch the output is generated only upon taking the magnet away not in introducing it to the switch. Power generated is in exes of the thousand volts and probably more because touching it you are destined to kiss the ground. I say probably more because it is impossible to use DMM it flies like nuts and is useless. In couple of passes I charge caps banks and light regular 40W neon power saver perfectly. Four footer Neon lights easily. In conclusion all I can say I played long enough with this little thing to know what it can do. I am certain power out exceeds input. I know what you are going to say here we go again. Well all can say in my defense, ask yourself what voltage is necessary to bridge such a gap and spark and you have it all. Experiment and try before asking questions or condemning it. Look at the bright side it is all in front of you. Do what you want. I have been on the boards long enough and spent countless hours in mu shop working and experimenting. To be so simple is a slap in the face. So one more who cares. From me to you.
Respectfully David.
http://www.youtube.com/watch?v=tM27VekKO08
http://www.youtube.com/watch?v=wG7ud711d_Q
