0 Members and 1922 Guests are viewing this topic.
energia9
Quote from: desa on October 31, 2010, 10:32:22 AM
Already been done...do research and save yourself the bench time.
E-Goose
My dear friend if you built Bedini you would definitely know this is nothing related to it. I spent many years experimenting with it and the most I got is 96% efficient runner. No sparks there I assure you. No matter how long you run it eventually you end up with empty battery. My ignition coil can’t do what this simple thing does. Build it and then come to comment on it.
@IWD I think it is more in Charles Flynn area of investigation. The Lincoln rods are regular welding rods used in metal fabrication welding. All shops where welding is done have it. I got my new Honeytec meter and measured again the coils are 23mH. Sorry about that. I don’t think it is relevant, any solenoid coil would doo. I think the reed switch is key to operation because of the sharp gradient of the closing. I think as the sharp pulls is introduced to the coils it dissipates internal field to the extremities. When the pulls stops the magnetic field returns with extra strength creating supercharged electric charge in the coils. I think this is most interesting aspect and by my humble opinion deserves more investigation.
I know this may be of the topic so I apologies in advance. I figured perhaps we could stay occupied until Cosmo decide to give us his final blessing. LOL..
David.
thank you, and dont worry it will be investigated, by me, today. i have all the parts including alnico reed switch, could you measure your coils inductance without the magnet please?
exnihiloest
Quote from: desa on October 30, 2010, 07:13:22 PM
Power generated is in exes of the thousand volts and probably more
A power is measured in watts not in volts.
I am certain power out exceeds input.
Could you show us your measurements and explain how you led them?
sigma16
It appears that one end of the large coil is not connected to anything.
The other end connects to the load.  Picture is of the coil in TK Home.  End of this coil is not visible during operation of the coil used outside.
Shokac
This is very important thing of Cosmo:
1. Take ferrite rod OR rod from toroid's wrap around Tesla coil with isolated cable connect it through sparkgap, other end to ground
make second coil around it and apply DC or AC current to make electromagnet
Results:
When HV are in first coil and DC or AC on second coil, you will not get an electromagnet, but if you turn off HV then ferrite turns into electromagnet. (now you can try to synchronise it with sparkgap and play with sparkgap polarisation) it need to spark with little needles very steady and quiet
Try it with AC and DC
Tesla worked with AC and with rotary breaker he break signal in half way, but we can work using generator for it, like Emitter Follower. but for start it is great to do it with AC - you can take 9 to 15 volts - good for start.
2. The key in SR device is to magnetize and demagnetize ferrite without loses.
High voltage and high frequency make ferrite demagnetise - it makes from ferrite Black Matter who sucks all electromagnet power from wires. and in this way this is effective way to demagnetize.
by the way, all scientists in the world try to make Black Matter without results, but there it is.
SR this process call "Dead Magnetic Field"
ramset
Thanks Grandma
