penno64
Hi,
Can someone please post a circuit to utilise spark to ground through coil.
I have a great little circuit for spark that only consumes 35 - 40mA after startup.
I just cannot picture how to get my spark gap in line with the coil and in between ground.
Any help appreciated.
Regards, Penno
poynt99
Quote from: Shokac on November 01, 2010, 11:37:27 AM
This is very important thing of Cosmo:
1. Take ferrite rod OR rod from toroid's wrap around Tesla coil with isolated cable connect it through sparkgap, other end to ground, make second coil around it and apply DC or AC current to make electromagnet.
Clarification and/or a drawing of the above quote would be very helpful.
Thanks,
.99
core
Quick questions while I build some stuff. Does Tariel use 1 or 2 ground wires? The green box video shows 2 the water pipe and car radiator. The 5KW unit (clear plastic) I think I see 1 only.
Looking at the 100KW unit, one bobbin looks like a transmitter and the other one a receiver. This one I guess would have two grounds.
Does anyone know how many grounds?
Respectfully,
Core
IWD
Results:
When HV are in first coil and DC or AC on second coil, you will not get an electromagnet, but if you turn off HV then ferrite turns into electromagnet. (now you can try to synchronise it with sparkgap and play with sparkgap polarisation) it need to spark with little needles very steady and quiet
Try it with AC and DC
Tesla worked with AC and with rotary breaker he break signal in half way, but we can work using generator for it, like Emitter Follower. but for start it is great to do it with AC - you can take 9 to 15 volts - good for start.
2. The key in SR device is to magnetize and demagnetize ferrite without loses.
High voltage and high frequency make ferrite demagnetise - it makes from ferrite Black Matter who sucks all electromagnet power from wires. and in this way this is effective way to demagnetize.
by the way, all scientists in the world try to make Black Matter without results, but there it is.
SR this process call "Dead Magnetic Field"
When you do that, then always when you see the spark, it means thath smal coil capacity is discharged (coil have always capacity which is charged, it is never only tension from magnetic field) That create a voltage acros coil wound on ferite conected to the ground, so also on another coil where ve have dc or ac. This voltage, if have oposite voltage as source will stop the current from source..for a while, so thus that can strongly decrease power delivered from source which creating magnet.
In more deep.. pulse from hv coil are of course short and weak, so as curent begin overprint curent from another source, then quickly fall, but magetic field in core will collaps even after that short time(domains of material returns to their position) source must again push current to coil, against inductive reactance, the material must be again magnetized, the domains must be again formated.
And if next hv pulse come before is material magnetized to level where we can recognize, then easily will be not magnetized. I do not see any magic.
Shokac
Quote from: core on November 01, 2010, 11:37:43 PM
Respectfully,
Core
I use 1
